Hello All,
I am a recent user with L4OM and am very happy with its utility. It worked great and I ran a pile up of 40 QSO in one hour during the SC QSO Party. Worked Great!!
I upgraded afterwards to the newest version and have recently had issues when I exit L4OM. The splash screen comes up with some dialog but it will not close. I have tried to let L4OM close itself for over an hour on several occasions but no joy.
I installed the latest TQSL but that did not help. Is there a setting I can look at or should I try an uninstall / reinstall?
Pictures show the hung splash screen and Task Manager (notice that TQSL is running)
Thanks for the help and 73,
Phillip
Log4OM not shutting down, Splash Screen stay up forever
- Screenshot 2023-03-01 175126.jpg (70.57 KiB) Viewed 1096 times
- Screenshot 2023-03-01 174600.jpg (59.45 KiB) Viewed 1096 times
Thanks and God Bless,
Phillip KQ4AJI, 73
ICOM-7300 with a 40-20-15-10-6 Fan Dipole
Phillip KQ4AJI, 73
Re: Log4OM not shutting down, Splash Screen stay up forever
Try turning off upload on program close in External services/LOTW of the Program configuration.
It worked! Do I need another change because now no LOTW are uploading? I know that the upload in a batch vs singles. I worked about 20 this weekend and none showed up on LOTW
Phillip KQ4AJI, 73
Phillip KQ4AJI, 73
Yes there are some situations when users uploads more than 10 QSO that cause a "stop answer" behaviour from TQSL application (Although TQSL executed as stand alone works perfectly).kq4aji wrote: 06 Mar 2023, 19:01 It worked! Do I need another change because now no LOTW are uploading? I know that the upload in a batch vs singles. I worked about 20 this weekend and none showed up on LOTW
There is an option in the log4om LOTW configuration to run TQSL as standalone, that fixes the upload issue.
So now set TQSL to run as a standalone then reset LOTW to upload on program close - that should fix the close down issue.
If you have some that have not uploaded you can do that manually in the QSL manager
Great, sounds like we are close.
I don't see "set TQSL to run as a standalone" option on the config>>external services>>LOTW tab. Am I in the right area?
- Screenshot 2023-03-06 190317.jpg (165.74 KiB) Viewed 1050 times
Phillip KQ4AJI, 73
Phillip KQ4AJI, 73
Enable TQSL Interactive mode
Worked like a champ. I re-enabled the "upload on program close" in External services/LOTW and it is behaving perfectly. Thanks again.
Phillip KQ4AJI, 73
Phillip KQ4AJI, 73
