WSJTX not in the applications configuration
n2ajo
Post by n2ajo »
Installed latest version of Log4OM2, v2.27.10. Integration of WSJTx is where I have an issue. I configured the connection for UDP however under the application submenu, FLDigi is the only application available. I have WSJTX installed on my computer. I must be missing something and any pointers are appreciated.
Log4OM
IC7610
WSJTX 2.6.1
Art N2AJO
Re: WSJTX not in the applications configuration
Art, you are not seeing this when you add a connection?
Settings/software integration/connections
You do not add anything else under applications for WSJT.
n2ajo
Post by n2ajo »
No I see that but the next step I can select shown below
Screenshot 2023-03-23 151701.jpg (39.82 KiB) Viewed 1261 times
Try downloading the latest user guide we moved on since your one
n2ajo
Post by n2ajo »
Terry
thanks for your input
I am on V2 of Log4OM not V1
The snapshot above is from page 205, Log4OM V2, Updated: 22/03/2023 5:53 PM which depicts WSJTX as an application under Settings, Program Integration, Software Integration, Applications. The application WSJTX doesn't appear even though I have it installed on my desktop and am able to start it via the Log4OM auto start feature.
So my question is what do I need to do to have WSJTX appear as an application as shown in the user manual
n2ajo wrote: 23 Mar 2023, 20:12 Terry
First an appology because I should have removed the screen shot about message 12 and will do so in next release of user guide. (EDIT: DONE)
I did realise that your on V2 so no mistake there
The WSJT menu was removed in this release because f the change to the way UDP connections are configured so you dont have an issue and you dont need to do anything re WSJT
n2ajo
Post by n2ajo »
thanks for the clarification. Much appreciated.
Art N2AJO
