Installed latest version of Log4OM2, v2.27.10. Integration of WSJTx is where I have an issue. I configured the connection for UDP however under the application submenu, FLDigi is the only application available. I have WSJTX installed on my computer. I must be missing something and any pointers are appreciated.
Log4OM
IC7610
WSJTX 2.6.1
Art N2AJO
WSJTX not in the applications configuration
Re: WSJTX not in the applications configuration
Art, you are not seeing this when you add a connection?
Settings/software integration/connections
You do not add anything else under applications for WSJT.
No I see that but the next step I can select shown below
- Screenshot 2023-03-23 151701.jpg (39.82 KiB) Viewed 1257 times
Try downloading the latest user guide we moved on since your one
Terry
thanks for your input
I am on V2 of Log4OM not V1
The snapshot above is from page 205, Log4OM V2, Updated: 22/03/2023 5:53 PM which depicts WSJTX as an application under Settings, Program Integration, Software Integration, Applications. The application WSJTX doesn't appear even though I have it installed on my desktop and am able to start it via the Log4OM auto start feature.
So my question is what do I need to do to have WSJTX appear as an application as shown in the user manual
First an appology because I should have removed the screen shot about message 12 and will do so in next release of user guide. (EDIT: DONE)n2ajo wrote: 23 Mar 2023, 20:12 Terry
I did realise that your on V2 so no mistake there
The WSJT menu was removed in this release because f the change to the way UDP connections are configured so you dont have an issue and you dont need to do anything re WSJT
Terry,
thanks for the clarification. Much appreciated.
Art N2AJO
Art N2AJO
