Problem with upload to HRDLOG service
sp5ah
Post by sp5ah »
For some time now I have a problem with the integration of LOG4OM with HRDLOG - it just doesn't work for me. In the User field I entered my login, and in the Code field I entered the code for upload, but the upload does not work. Can someone help me?
If I try upload by QSL Manager I've Errors:
"upload result [ERROR] 2 qso: Callsign: SQ5..... Date: 26.10.2022 21:17:52 Band: 2m Mode: FM"
'73
Re: Problem with upload to HRDLOG service
It's an error returned from HRDLOG service, i don't know what is the reason, but i can ask.
I suggest you to write a ticket to them too.
sp5ah
Post by sp5ah »
IW3HMH wrote: 22 Mar 2023, 07:36 It's an error returned from HRDLOG service, i don't know what is the reason, but i can ask.
I'm trying to find a place where you can create such a request on HRDLOG.NET...
Main Site on the right down. Contact us.
sp5ah
Post by sp5ah »
DF5WW wrote: 22 Mar 2023, 13:38 Main Site on the right down. Contact us.
Already reported.
Thank you
sp5ah
Post by sp5ah »
After reporting it, HRDLOG.NET Support sent me the Upload Code again but it still doesn't work with it:
upload result [ERROR] qso: Callsign: CT2GSN Date: 19.03.2023 17:53:57 Band: 10m Mode: USB
HRDLOG END
They wrote me that if the upload does not work, I should write on the LOG4OM forum
"Hi Piotr,
your upload code is .........
If you are using the correct code then write to the LOG4OM support forum"
Iw7dol
Post by Iw7dol »
The upload with HRDLOG was working until the last release: on 2.27 it doesn't work!
Iw7dol wrote: 24 Mar 2023, 09:07 The upload with HRDLOG was working until the last release: on 2.27 it doesn't work!
My guess is that you are using FT8 and have not followed the instructions here viewtopic.php?t=8260
Because I just auto uploaded two QSO's to HRDLog without issues, see below
sp5ah
Post by sp5ah »
I'm using 2.25 (for SSB QSO) becouse in 2.26 is problem with downloading of Grid Square from e.g. qrz.com . I tried 2.24 but HRDLOG.NET upload doesn't work too.
sp5ah wrote: 24 Mar 2023, 10:56 I'm using 2.25 (for SSB QSO) becouse in 2.26 is poroblem with downloadin of Grid Square. I tried 2.24 but HRDLOG.NET upload doesn't work too.
You need t update to 2.27.1.0 ASAP
