Good day,
when clicking on a callsing in the DX cluster list, sometimes there is a delay in frequency switching.
The delay is randomic and it might happen when double clicking on a callsign. Being in the same or different band doesn't change behaviour.
When it happen i can see it is stacked because of the callsign data lookup.
Is there any way to give priority to switching instead of data lookup ?
My PC is a pretty fast gaming PC, the network is GBit and WAN is low latency between 40-60MBps.
Max IU4JNR
DX-Cluster callsign selection - Delay in freq switching
Re: DX-Cluster callsign selection - Delay in freq switching
No way to switch priority but what radio and are you using Omnirig or Hamlib
Also what version number of Log4OM are you using - WE ALWAYS NEED THIS
It can be causing by heavy working VOACAP function.
If you have VOACAP enabled, disable it and try if it's helping.
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
73!
de EI6KW, Slav
Good evening Terry,G4POP wrote: 30 Mar 2023, 11:46 No way to switch priority but what radio and are you using Omnirig or Hamlib
I have 2 radios. A Flex6400 which I connect with omnirig and a SunSdr2 dx which I connect with TCI.
The version is 2.27.1 stable but also with the beta has Sam behaviour.
Best,
Max IU4JNR
Thanks Slav, I will try that.ei6kw wrote: 30 Mar 2023, 14:57 It can be causing by heavy working VOACAP function.
Max IU4JNR
You're welcome, Max. I'm happy it helped.
__
73!
de EI6KW, Slav
73!
de EI6KW, Slav
