DX-Cluster callsign selection - Delay in freq switching
iu4jnr
Post by iu4jnr »
Good day,
when clicking on a callsing in the DX cluster list, sometimes there is a delay in frequency switching.
The delay is randomic and it might happen when double clicking on a callsign. Being in the same or different band doesn't change behaviour.
When it happen i can see it is stacked because of the callsign data lookup.
Is there any way to give priority to switching instead of data lookup ?
My PC is a pretty fast gaming PC, the network is GBit and WAN is low latency between 40-60MBps.
Max IU4JNR
Re: DX-Cluster callsign selection - Delay in freq switching
No way to switch priority but what radio and are you using Omnirig or Hamlib
Also what version number of Log4OM are you using - WE ALWAYS NEED THIS
ei6kw
Post by ei6kw »
It can be causing by heavy working VOACAP function.
If you have VOACAP enabled, disable it and try if it's helping.
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
iu4jnr
Post by iu4jnr »
G4POP wrote: 30 Mar 2023, 11:46 No way to switch priority but what radio and are you using Omnirig or Hamlib
Good evening Terry,
I have 2 radios. A Flex6400 which I connect with omnirig and a SunSdr2 dx which I connect with TCI.
The version is 2.27.1 stable but also with the beta has Sam behaviour.
Best,
Max IU4JNR
iu4jnr
Post by iu4jnr »
ei6kw wrote: 30 Mar 2023, 14:57 It can be causing by heavy working VOACAP function.
Thanks Slav, I will try that.
Max IU4JNR
iu4jnr
Post by iu4jnr »
iu4jnr wrote: 31 Mar 2023, 19:53
Max IU4JNR
Slav,
good catch ;)
Now switching is real time.
Thank you very much
Max
IU4JNR
ei6kw
Post by ei6kw »
You're welcome, Max. I'm happy it helped.
__
73!
de EI6KW, Slav
