Same thing with GB7MBC.
Restarted after checking Keep Alive around 14:50
Routine activity from Cluster
Last update was 16:09 (interesting that it has been :09 in both traced instances)
I noticed @16:30 last update was about 20 minutes old. Opened Telnet Cluster Management Sent Show/Announce and it disconnected. No apparent errors in log. I will restart and wait to see it fully disconnect on its own to see if the application reports something wrong.
Again, never had this issue running 2 clusters under 2.26
v2.27.1.0 Cluster connections disconnect randomly
Re: v2.27.1.0 Cluster connections disconnect randomly
Restarted Cluster connection 17:12
Last Update 19:30 ( I noticed it about 20:10 but left it alone)
Disconnect 21:30 Telnet connection GB7MBC doesn't answer anymore. Disconnecting
I am going to try VE7CC because both GB7MBC and VE2HEW are DXSpiders. And see what happens.
Same pattern with VE7CC.
Start Cluster 23:15
Last Update: 00:51
Noticed old Last update 01:32
L4OM Disconnects 02:51 (seems to 2 2hrs since last comms with cluster)
Question: Should I be seeing some type of keep alive message to the cluster? some command like a ping or ??
No mention of Cluster or Telnet between Last Update and Disconnect period in the log.
Brian
W1BKW
Start Cluster 23:15
Last Update: 00:51
Brian
W1BKW
I went back to GB7MBC and VE2HEW and random "sleep" and/or disconnects continue.
Here is the latest log snip from the point of "Last update"
2023-05-03 10:48:53.1758 TRACE: [ClusterManagement][dje_zULDH2DW49AA8X4Q_ejd] : [CLUSTER INBOUND MESSAGE] DX de MR0GOR: 21285.0 JD1BQP QSX 21290.00 USB 1049Z from www.gb7mbc.net:8000
2023-05-03 10:48:53.2467 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : Performing QSO search on callsign JD1BQP
2023-05-03 10:48:53.2467 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call JD1BQP on date 5/3/2023 10:48:53 AM
2023-05-03 10:48:53.2497 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : No Clublog CQ ZONE found for JD1BQP
2023-05-03 10:48:53.2497 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : Searching clublog exceptions
2023-05-03 10:48:53.2497 TRACE: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : No Clublog exceptions found for JD1BQP
2023-05-03 10:48:53.2497 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : LOTW user identified
2023-05-03 10:48:53.2497 DEBUG: * [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext][3 ms] : QSO search on callsign JD1BQP completed
2023-05-03 10:48:53.2497 DEBUG: * [Countries][SearchCallsign][3 ms] : Performing Search Callsign on call JD1BQP on date 5/3/2023 10:48:53 AM
2023-05-03 10:48:53.2654 TRACE: [ProgramStorage][GetFlag] : Flag OGA identified.
2023-05-03 10:48:53.2654 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call MR0GOR on date 5/3/2023 10:48:53 AM
2023-05-03 10:48:53.2654 DEBUG: [dje_zGSLBCCQ8HTEPDLX4HCUJL225A6XQ_ejd][MoveNext] : SPOT mode overriden to USB
2023-05-03 10:48:53.2654 DEBUG: [dje_zJXGMRCM6YLQ6LMX77E5BF_ejd][MoveNext] : Loading Awards items from database for multiple award codes
2023-05-03 10:48:53.2810 TRACE: [ClusterManagement][dje_zULDH2DW49AA8X4Q_ejd] : [CLUSTER INBOUND MESSAGE] DX de MR0GOR: 21285.0 JD1BQP QSX 21290.00 USB 1049Z from dx.ve2hew.com:7300
2023-05-03 10:48:53.2810 DEBUG: * [dje_zJXGMRCM6YLQ6LMX77E5BF_ejd][MoveNext][15 ms] : Awards reference list retrieved from database
2023-05-03 10:48:53.2810 TRACE: [dje_zGSLBCCQ8HTEPDLX4HCUJL225A6XQ_ejd][MoveNext] : Cluster ranking search: DXCC 192 Ogasawara -> 125
2023-05-03 10:48:53.2966 TRACE: [dje_zEAPSMH3FDXTUY9WA9ASQZ_ejd][MoveNext] : Adding 1 spots to cluster database
2023-05-03 10:48:53.8989 TRACE: [dje_zSVWLZB3YQ5M6KNQ35ZSVF_ejd][MoveNext] : Executing planned scheduler...
2023-05-03 10:48:53.8989 TRACE: [LogWriter][DumpProcess] : ## DUMP MODULES ##
2023-05-03 10:48:53.8989 TRACE: [LogWriter][DumpProcess] : ## DUMP ##SearchCallsign Countries 1
2023-05-03 10:48:53.8989 TRACE: [dje_zSVWLZB3YQ5M6KNQ35ZSVF_ejd][MoveNext] : Planned scheduler executed...
I really feel like rolling back to .26 would be an appropriate troubleshooting method to determine if it is .27 related or something else. I never had this problem on .26 Is it problematic to rollback?
Is your internet connection via a plug in wifi USB dongle
Incidentally my cluster uses GB7MBC and VE7CC and it has been running continuously for 14 hours so far testing version 2.27.1.2
FWIW - I enabled the GB7MBC cluster feed along with VE7CC and another I use for POTA spots since this thread started and I have not had any timeouts or loss of signal.
That has been since 26 April 2023.
Have to agree with Terry it appears to be due to your internet connection and not a bug/problem with Log4OM.
PC running L4OM is on a 8 port gig switch directly attached to the router. No other disconnect symptoms for any other devices (and there are many).
1) with the Keep Alive option enabled, shouldn't I see keep alive messages in the telnet command window and in the Trace log? when it has basically gone to sleep but not disconnected yet, I would expect to see keep alive messages with no response??
change to debug mode you will see a ping and pong
Here is a log snip from the Last Updated time forward for awhile. Ping/Pong shows the network still active but the cluster is not communicating.
2023-05-08 18:51:49.7712 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : Performing QSO search on callsign OQ95RCL
2023-05-08 18:51:49.7712 DEBUG: * [Countries][SearchCallsign][190018 ms] : Performing Search Callsign on call OQ95RCL on date 5/8/2023 6:51:49 PM
2023-05-08 18:51:49.7712 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : No Clublog CQ ZONE found for OQ95RCL
2023-05-08 18:51:49.7712 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : Searching clublog exceptions
2023-05-08 18:51:49.7712 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : LOTW user identified
2023-05-08 18:51:49.7712 DEBUG: [dje_z9TE3N2ECQYX4FX8XEDTUGTWMZCLZ62TN4Q_ejd][MoveNext] : QSO search on callsign OQ95RCL completed
2023-05-08 18:51:49.7712 DEBUG: [Countries][SearchCallsign] : Performing Search Callsign on call OQ95RCL on date 5/8/2023 6:51:49 PM
2023-05-08 18:51:49.7948 DEBUG: * [Countries][SearchCallsign][23 ms] : Performing Search Callsign on call ON4KCY on date 5/8/2023 6:51:49 PM
2023-05-08 18:52:05.3973 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:52:25.2211 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 18:52:35.5335 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 18:52:35.5633 DEBUG: * [FWWeb][CheckInternetConnection][29 ms] : ...Pong - Network connection OK
2023-05-08 18:53:05.7198 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:54:05.6052 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:54:49.0154 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2023-05-08 18:54:49.0183 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2023-05-08 18:55:05.7000 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:56:05.7983 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:57:05.9335 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:57:25.2229 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 18:58:06.0450 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 18:59:06.1377 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:00:06.2284 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:01:06.3744 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:01:06.3794 INFO: [dje_z87P8XFFSWGRXX3UB3WVYG3PM9FPQ_ejd] : [UPDATE] Clublog Reference update start
2023-05-08 19:01:06.3824 INFO: [dje_zDXJ6XAEDKWU25GRPVX6ZVHVW23AA_ejd] : [UPDATE CLUBLOG RANKING] Downloading Clublog ranking from https://clublog.org/mostwanted.php?api=1
2023-05-08 19:01:06.3824 DEBUG: [dje_zWLLTLAPP2CF4X4U7XRSECJBG2DAQ_ejd][MoveNext] : GetStringFromUrlAsync: Retrieving data from URL https://clublog.org/mostwanted.php?api=1
2023-05-08 19:01:06.8407 DEBUG: * [dje_zWLLTLAPP2CF4X4U7XRSECJBG2DAQ_ejd][MoveNext][458 ms] : GetStringFromUrlAsync: Data from URL https://clublog.org/mostwanted.php?api=1 downloaded
2023-05-08 19:01:06.8437 DEBUG: [dje_zDXJ6XAEDKWU25GRPVX6ZVHVW23AA_ejd][MoveNext] : [UPDATE CLUBLOG RANKING] Saving ranking file to C:\Users\brian\AppData\Roaming\Log4OM2\ranking.csv
2023-05-08 19:01:06.8457 DEBUG: [FwFile][WriteTextFileFromDictionary] : Begin writing text file C:\Users\brian\AppData\Roaming\Log4OM2\ranking.csv
2023-05-08 19:01:06.8467 DEBUG: [FwFile][WriteTextFileFromDictionary] : Text file write completed C:\Users\brian\AppData\Roaming\Log4OM2\ranking.csv
2023-05-08 19:01:06.8506 INFO: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd] : [UPDATE CLUBLOG] Downloading Clublog database from https://cdn.clublog.org/cty.php?api=295 ... a7dd1750c9
2023-05-08 19:01:06.8506 DEBUG: * [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext][3511803 ms] : DownloadFileFromUrlAsync: Downloading file from URL https://cdn.clublog.org/cty.php?api=295 ... a7dd1750c9 into C:\Users\brian\AppData\Roaming\Log4OM2\temp\cty.xml.gz
2023-05-08 19:01:07.6187 DEBUG: [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext] : DownloadFileFromUrlAsync: file from URL https://cdn.clublog.org/cty.php?api=295 ... a7dd1750c9 downloaded
2023-05-08 19:01:07.6187 INFO: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd] : [UPDATE CLUBLOG] Decompressing file C:\Users\brian\AppData\Roaming\Log4OM2\temp\cty.xml.gz in C:\Users\brian\AppData\Roaming\Log4OM2\temp\cty.xml
2023-05-08 19:01:07.6795 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Parsing XML file C:\Users\brian\AppData\Roaming\Log4OM2\temp\cty.xml
2023-05-08 19:01:07.8693 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Parsing XML file - Exceptions
2023-05-08 19:01:09.6901 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Parsing XML file - Prefixes as full callsigns
2023-05-08 19:01:10.0245 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Parsing XML file - Invalid operations
2023-05-08 19:01:10.1256 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Parsing XML file - Zone exceptions
2023-05-08 19:01:10.3327 DEBUG: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Saving clublog.xml file in C:\Users\brian\AppData\Roaming\Log4OM2\clublog.xml
2023-05-08 19:01:10.3327 DEBUG: [FwFile][SerializeObject] : Serializing C:\Users\brian\AppData\Roaming\Log4OM2\clublog.xml
2023-05-08 19:01:10.4932 DEBUG: [FwFile][SerializeObject] : Serialization completed C:\Users\brian\AppData\Roaming\Log4OM2\clublog.xml
2023-05-08 19:01:10.4932 WARN: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Clublog country not found in archive: 997
2023-05-08 19:01:10.4932 WARN: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd][MoveNext] : [UPDATE CLUBLOG] Clublog country not found in archive: 998
2023-05-08 19:01:10.4932 INFO: [dje_zEDP5XBTMM9F6J2M23EJPPVBNA9WYRDJGKW_ejd] : [UPDATE CLUBLOG] Clublog database retrieved successfully
2023-05-08 19:01:10.4932 INFO: * [dje_z87P8XFFSWGRXX3UB3WVYG3PM9FPQ_ejd][4113 ms] : [UPDATE] Clublog Reference update end
2023-05-08 19:01:10.4932 INFO: [dje_z95N6USGYNYE3NR7BKMGKGQN6VR4ML7U5TPEUEUYX_ejd] : [UPDATE] Special Callsign file update start
2023-05-08 19:01:10.5000 DEBUG: * [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext][2881 ms] : DownloadFileFromUrlAsync: Downloading file from URL https://www.log4om.com/l4ong/resources/ ... llsign.txt into C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0709 DEBUG: [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext] : DownloadFileFromUrlAsync: file from URL https://www.log4om.com/l4ong/resources/ ... llsign.txt downloaded
2023-05-08 19:01:11.0728 DEBUG: [FwFile][ComposeFilename] : ComposeUserFilename: Returning file C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0738 INFO: [ConfigurationLogic] : Non Standard callsign begin load from file C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0738 INFO: [ConfigurationLogic] : Non Standard callsign load from file completed
2023-05-08 19:01:11.0748 DEBUG: [FwFile][LoadFileAsList] : LoadFileAsList: Begin load text file C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0748 DEBUG: [FwFile][LoadFileAsList] : LoadFileAsList: Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0748 DEBUG: [FwFile][LoadFileAsHashSet] : Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\NonStandardCallsign.txt
2023-05-08 19:01:11.0758 INFO: * [dje_z95N6USGYNYE3NR7BKMGKGQN6VR4ML7U5TPEUEUYX_ejd][582 ms] : [UPDATE] Special Callsign file update end
2023-05-08 19:02:06.5027 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:02:25.2329 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:02:36.5344 INFO: [dje_zYWPW329Q7FBWDMTTGQVKMDPX9REQ_ejd] : [UPDATE] Refreshing solar data start
2023-05-08 19:02:36.5344 INFO: [dje_zLYFALWJA3JTZ8FQXQYYW62U97EUVZ9JCTQ_ejd] : Loading Geomagnetic data series
2023-05-08 19:02:36.5354 INFO: [dje_zLYFALWJA3JTZ8FQXQYYW62U97EUVZ9JCTQ_ejd] : GEOMAGNETIC DATA (DGD) downloading from https://services.swpc.noaa.gov/text/dai ... ndices.txt
2023-05-08 19:02:36.5354 DEBUG: * [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext][85463 ms] : DownloadFileFromUrlAsync: Downloading file from URL https://services.swpc.noaa.gov/text/dai ... ndices.txt into C:\Users\brian\AppData\Roaming\Log4OM2\DGD.txt
2023-05-08 19:02:36.7218 DEBUG: [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext] : DownloadFileFromUrlAsync: file from URL https://services.swpc.noaa.gov/text/dai ... ndices.txt downloaded
2023-05-08 19:02:36.7247 INFO: [dje_zLYFALWJA3JTZ8FQXQYYW62U97EUVZ9JCTQ_ejd] : GEOMAGNETIC DATA (DGD) load from file completed
2023-05-08 19:02:36.7247 INFO: [dje_z52W45EE4B7PA675PEEB4BXKTGE8U6NA7ZX_ejd] : Loading Solar data series
2023-05-08 19:02:36.7257 INFO: [dje_z52W45EE4B7PA675PEEB4BXKTGE8U6NA7ZX_ejd] : GEOMAGNETIC DATA (DSD) downloading from https://services.swpc.noaa.gov/text/dai ... ndices.txt
2023-05-08 19:02:36.7257 DEBUG: * [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext][3 ms] : DownloadFileFromUrlAsync: Downloading file from URL https://services.swpc.noaa.gov/text/dai ... ndices.txt into C:\Users\brian\AppData\Roaming\Log4OM2\DSD.txt
2023-05-08 19:02:36.7521 DEBUG: [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext] : DownloadFileFromUrlAsync: file from URL https://services.swpc.noaa.gov/text/dai ... ndices.txt downloaded
2023-05-08 19:02:36.7521 INFO: [dje_z52W45EE4B7PA675PEEB4BXKTGE8U6NA7ZX_ejd] : GEOMAGNETIC DATA (DSD) load from file completed
2023-05-08 19:02:36.7521 INFO: [dje_z2B47WSEVEBCQWMVMMNJKR6EVT9HE7FUVMTCRA2TNGZZMNE2_ejd] : Loading Predicted Solar data
2023-05-08 19:02:36.7688 INFO: [dje_z2B47WSEVEBCQWMVMMNJKR6EVT9HE7FUVMTCRA2TNGZZMNE2_ejd] : GEOMAGNETIC DATA (Predicted) downloading from https://services.swpc.noaa.gov/json/sol ... cycle.json
2023-05-08 19:02:36.7698 DEBUG: * [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext][18 ms] : DownloadFileFromUrlAsync: Downloading file from URL https://services.swpc.noaa.gov/json/sol ... cycle.json into C:\Users\brian\AppData\Roaming\Log4OM2\predicted-solar-cycle.json
2023-05-08 19:02:36.8324 DEBUG: [dje_zXXFZ8MM8SRJAV65VYZ8GYJ42ZDEQ_ejd][MoveNext] : DownloadFileFromUrlAsync: file from URL https://services.swpc.noaa.gov/json/sol ... cycle.json downloaded
2023-05-08 19:02:36.8344 DEBUG: [FwFile][LoadFile] : Begin load text file C:\Users\brian\AppData\Roaming\Log4OM2\predicted-solar-cycle.json
2023-05-08 19:02:36.8364 DEBUG: [FwFile][LoadFile] : Text file load completed C:\Users\brian\AppData\Roaming\Log4OM2\predicted-solar-cycle.json
2023-05-08 19:02:36.8521 INFO: [dje_z2B47WSEVEBCQWMVMMNJKR6EVT9HE7FUVMTCRA2TNGZZMNE2_ejd] : GEOMAGNETIC DATA (Predicted) load from file completed
2023-05-08 19:02:36.8521 INFO: [dje_z74B36PUHBBAZXMPBDGUZTDUCEZ458EAMHLPK52C6_ejd] : Calculating HOURLY VOACAP data: FN44pd with 100.0 watts and 99 sun spots on hour: 19
2023-05-08 19:02:36.8521 INFO: * [dje_zYWPW329Q7FBWDMTTGQVKMDPX9REQ_ejd][317 ms] : [UPDATE] Refreshing solar data end
2023-05-08 19:02:36.8521 INFO: [dje_zZLM7NVPGAC8S2BQWVTZX5C2GDSTY63AF52_ejd] : [UPDATE] Refreshing METAR data start
2023-05-08 19:02:37.0689 INFO: * [dje_zZLM7NVPGAC8S2BQWVTZX5C2GDSTY63AF52_ejd][216 ms] : [UPDATE] Refreshing METAR data end
2023-05-08 19:02:37.1359 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 19:02:37.1711 DEBUG: * [FWWeb][CheckInternetConnection][34 ms] : ...Pong - Network connection OK
2023-05-08 19:02:37.2000 DEBUG: [FwFile][WriteFile] : Begin writing text file C:\Users\brian\AppData\Roaming\Log4OM2\temp\VOACAP_HOURLY_INPUT.JSON
2023-05-08 19:02:37.2010 DEBUG: [FwFile][WriteFile] : Text file write completed C:\Users\brian\AppData\Roaming\Log4OM2\temp\VOACAP_HOURLY_INPUT.JSON
2023-05-08 19:02:37.2010 DEBUG: [FwFile][WriteFile] : Begin writing text file C:\Users\brian\AppData\Roaming\Log4OM2\temp\VOACAP_HOURLY_OUTPUT.json
2023-05-08 19:02:37.2024 DEBUG: [FwFile][WriteFile] : Text file write completed C:\Users\brian\AppData\Roaming\Log4OM2\temp\VOACAP_HOURLY_OUTPUT.json
2023-05-08 19:02:37.2421 INFO: [dje_z74B36PUHBBAZXMPBDGUZTDUCEZ458EAMHLPK52C6_ejd] : Hourly VOACAP calculation completed
2023-05-08 19:03:06.8487 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:04:01.7182 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:05:01.7941 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:06:01.9078 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:07:01.9864 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:07:25.2401 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:08:02.0771 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:09:02.2014 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:10:02.3281 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:11:02.4280 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:12:02.5177 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:12:25.2507 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:12:32.6483 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 19:12:32.6856 DEBUG: * [FWWeb][CheckInternetConnection][37 ms] : ...Pong - Network connection OK
2023-05-08 19:13:02.8244 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:14:02.7485 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:15:02.8668 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:16:02.9925 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:17:03.1174 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:17:25.2521 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:18:03.1944 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:19:03.2978 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:20:03.4025 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:21:03.4809 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:22:03.5671 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:22:25.2559 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:22:33.6835 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 19:22:33.7176 DEBUG: * [FWWeb][CheckInternetConnection][34 ms] : ...Pong - Network connection OK
2023-05-08 19:23:03.8665 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:24:03.8052 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:25:03.9517 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:26:04.0787 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:27:04.1526 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:27:25.2626 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:28:04.2489 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:29:04.3553 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:30:04.4818 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:31:04.6106 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:32:04.7281 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:32:25.2672 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:32:34.8698 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 19:32:34.8730 DEBUG: * [FWWeb][CheckInternetConnection][3 ms] : ...Pong - Network connection OK
2023-05-08 19:33:05.0651 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:34:04.9551 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:35:05.1027 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:36:05.2091 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:37:05.3043 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:37:25.2749 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:38:05.4491 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:39:05.5272 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:40:05.6487 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:40:09.7032 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS NOT RESPONDING
2023-05-08 19:40:09.7071 INFO: [OmnirigEngine] : CAT OMNIRIG2 -> LOG4OM RIG1 IS ONLINE
2023-05-08 19:41:05.7441 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:42:05.8725 DEBUG: [dje_zXKBMXJSRAJJ29RCRXFDHD_ejd][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
2023-05-08 19:42:25.2753 DEBUG: [FwFile][JsonSerializeObjectToString] : Serializing content from L4ONG.BE.Talk.ChatMessage
2023-05-08 19:42:36.0222 DEBUG: [FWWeb][CheckInternetConnection] : Ping...
2023-05-08 19:42:36.0531 DEBUG: * [FWWeb][CheckInternetConnection][30 ms] : ...Pong - Network connection OK
