log4om + Omnirig + flrig
KC3UDZ
Post by KC3UDZ »
Hello All,
OK, I've searched and found many related threads, but none (that I have found) answer my question exactly.
I would like to use FLRig for CAT control of my Yaesu FT-891
And Log4OM using Omnirig if possible. I have used Hamlib with limited success. Hamlib will hook-up and then drop out after just a few seconds. VERY frustrating.
In the other threads that I have found on this subject, Terry suggests Omnirig, but I can't for the life of me figure out how, because FLRig is using COM4.
I'm sure there's a way to all three (FT-891, FLRig & Log4OM) talking to each other! Would someone who's using this (or similar) combination please give me a quick "how-to"?
TIA,
Muggs KC3UDZ
Muggs - KC3UDZ
ei6kw
Re: log4om + Omnirig + flrig
Post by ei6kw »
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
KC3UDZ
Post by KC3UDZ »
Slav,
Thank you, but I have already seen that post. Like I said, Hamlib hooks up and drops out after 5-10 seconds.
I don't understand why this is so hard. It's obviously something that I am doing wrong, but the solution escapes me.
Muggs KC3UDZ
Muggs - KC3UDZ
KC3UDZ wrote: 25 Jun 2023, 22:13 Slav,
Muggs KC3UDZ
And your Log4OM version number is?
KC3UDZ
Post by KC3UDZ »
2.28.0.0
Muggs - KC3UDZ
KC3UDZ wrote: 25 Jun 2023, 22:22 Terry,
2.28.0.0
I asked because we had an issue in an earlier release but its fixed in the version your using.
I thought there was a choice in FLrig to use Omnirig rig 1 or 2 in the radio list, can you check please?
KC3UDZ
Post by KC3UDZ »
No. There is just Omni-VII and OMNI-VI. Whatever they are.
Muggs - KC3UDZ
KC3UDZ
Post by KC3UDZ »
Bump.
Muggs - KC3UDZ
KC3UDZ wrote: 26 Jun 2023, 13:29 Terry,
They are Ten Tec radios!
Did you refer to this thread which has a hint viewtopic.php?t=3371
QUOTE:
I've found I can copy rigctld and these files
12/19/2014 09:54 PM 507,989 libgcc_s_sjlj-1.dll
03/31/2018 08:13 AM 2,613,248 libhamlib-2.dll
09/13/2015 08:00 PM 252,580 libusb-1.0.dll
01/21/2015 05:40 PM 67,008 libusb0.dll
09/11/2014 04:34 PM 251,903 libwinpthread-1.dll
And Log4OM can connect to everything in the new version. I updated riglist.txt to show the new rigs.
I am now trying to run either hamlib NET rigctl or the FLRig entry. I can get both to run just by using the parameter "--model=2" or "--model=4".
