V2.28 & Grid Squares
W4RXK
Post by W4RXK »
For reasons unknown, my QSO grids are incorrect. For example, when logging field day contact this weekend, W7SP in Utah displays a grid from Nevada (DN11). The correct grid is DN40.
When I select the globe to update the QSO, it populates with the correct grid.
However, when I use the QSO manager, the grid does not change.
I noticed the problem when using a QSO mapping tool. Many of my contacts were incorrect. For example, I had zero contacts in Nevada, but several in Utah. Because of the incorrect grid for the Utah station, it maps to Nevada.
Is there an automated way to refresh the grid squares my my previous contacts? This weekend was 500+ and not an easy process to validate and update each one.
QRZ is my primary source; I am not a paid subscriber. What is the best way to ensure the grids are accurate? What is a good source? I noticed HAMCALL (online) provides the correct grid square with the full 6 characters (e.g., DN40bu).
I also cannot change the REALTIME LOGGING and HISTORIC QSO settings. There are no drop downs.
Re: V2.28 & Grid Squares
Ray,
Without having at least an XML Subscriber Membership at QRZ.com you will not get the more granular data for any callsign lookups.
As an alternative you can utilize HamQTH for the lookups. It is a 'free' source for callsign lookups. It is not as robust at QRZ.com and often relies on an individual OM to provide more granular detail for their database. Whereas QRZ.com gets a feed from the FCC on some basis.
You should tic using the CTY database as that might have helped better pinpoint some of those QSOs you made. I can't guarantee that, but would guess that might be an assist.
The changes to Realtime Logging and Historic Logging were made with V 2.24.0.0 and V 2.26.0.0 ... this was due to so many options that ended up conflicting with one another and giving virtually everyone bad / incorrect grid IDs. Using certain sort order settings was causing a lot of issues.
Lele made the changes after we tested for well over a month and have not had any issues since that time.
Save for the fact that QRZ.com provides one level of data with "no" subscription and a more in-depth level of data with at least the XML Subscription.
Screen clips below show two lookups I did for w7sp ... one with my QRZ.com "XML Subscription" and the other with my "free" login at HamQTH.
W4RXK
Post by W4RXK »
Nolan, thank you for helping!
Ok, here's a headscratcher ... I have my info providers selected for QRZCQ only as 'primary' and 'web external source'. I also have CTY enabled.
For this test call sign, W4RDN in EM77WX, Log4OM returns EM83 (in Georgia). When I look the call sign up @ QRZ and QRZCW, the call sign grid is EM77WX.
If I untick CTY, I get no grid detail. I presume EM83 is a common grid for W4*
I must have something misconfigured in the settings because Log4OM will not return the correct grid location.
If you dont have an XML subscription to QRZ you do NOT received a locator from QRZ
In the absense of a locator being found using the online source Log4OM uses internal data to select a locator at the aproximate centre of the country indicated by the call sign prefix
W4RXK
Post by W4RXK »
Hi G4POP, thanks for responding.
If I can manually lookup via QRZCQ.com, why would it not work in Log4OM? Based on my testing, I was able to retrieve data form HAMQTH for a few accounts. Not everyone is registered in multiple sites.
What provider(s) do you use for accurate data?
W4RXK wrote: 27 Jun 2023, 01:04 Hi G4POP, thanks for responding.
Ray,
There is no perfect d/b, but QRZ.com is the best/better of them all. Yes, it costs a little bit for the XML Data Subscription (in fact I just renewed mine yesterday for 3-years), but it is good.
HamQTH is the other source we suggest, but (as you have noted) it does not have all hams in the d/b. There are many OMs who refuse to have their data in QRZ.com and only use HamQTH and/or vice-versa.
As for QRZCQ I choose to not have my data at that site.
At my station I use QRZ.com and HamQTH.
W4RXK
Post by W4RXK »
Thank you Nolan.
Because when Log4OM ask's QRZ for the data its linked to your user name, password and the API facility in QRZ - QRZ know that you have not paid so THEY restrict the information they provide to that lookup request.
Personally I pay for a QRZ XML subscription the cost of which is minimal when I consider my investment in the hobby with equipment and membership to national organisations etc., If I did not subscribe to QRZ I would use HamQTH for a primary lookup.
W4RXK
Post by W4RXK »
Thank you Terry.
By the way, on QRZCQ its the same story. No payed account no complete data.
