I see the above in "self care" information.
I get this all the time when I download LOTW. I have been trying to find why for it seems forever.
I can see getting this once but every time. Is this normal and if not is there a way to get rid of it?
If normal I can live with it but I have been wondering why I have been getting it. I have discussed with ARRL LOTW an was informed not their doing.
Thanks,
Greg
UPDATE_CQ_ITUZONE
Re: UPDATE_CQ_ITUZONE
First of all it helps if you state what Log4OM version number your using?
I just did an LOTW download and then inspected the 'Self care information' data and there was no trace of the message you have.
Can you do a snip of the message but PLEASE DONT INCLUDE THE PASSWORD SECTION and post it as a screen shot
Sorry, but I was locked out yesterday for some reason. It said I was blocked, black listed be cause of my IP address but it seems OK now. I copied what I get if I open the self care UDP connections. I do not have any update_CQ_ITUZONE in my connections set up. I am running 2.28.0.0
Greg
INBOUND UDP CONNECTIONS
[UDP_INBOUND] [ADIF_MESSAGE] [2234] INCOMING JTALERT/GT ADIF
Parameters:
USE_EXTERNAL_DATA
UPLOAD_QSO
UPDATE_CQ_ITUZONE
Greg
Parameters:
USE_EXTERNAL_DATA
UPLOAD_QSO
UPDATE_CQ_ITUZONE
Yes there was a general issue with users caused by a spammer
I need to see the message which includes the zone text in the title of your forum post please
You lost me. Zone text....you mean the download from LOTW or something in Log4OM?
You said see the title of this thread which is UPDATE_CQ_ITUZONE
I need to see the message that contains that text (UPDATE_CQ_ITUZONE)
That is all there is. That is the entire message.
If I hoover over the message I get the parameters. The parameters do not show as a message anywhere that I can find.
Greg
Greg
Greg,
You noted in your original post that you see the "update_cq_ITUzone" label in your Self Care Information.
Terry is asking where you see that? I've tested as well as also can't see that label in my Self Care Information.
If you are seeing it in the Self Care Information he is wanting a clip of that information, but advised you to NOT let your logins/passwords be visible.
Maybe you are not being quite clear on where you were seeing that label?
Greg,
If you are asking where the "UPDATE_CQ_ITUZONE" label is coming from ... well it is related to the UDP Inbound Connections you have set up for the FTxx mode operations from WJSTx and JTAlert.
I have similar in my Self Care Information. Clips below show what shows up in my Self Care information and I've also provided a clip showing the UDP Inbound Connection that drives such information to be saved.
Is this what you are referring to?
- ki5io-self-care-1.JPG (32.93 KiB) Viewed 899 times
- ki5o-udp-inbound.JPG (86.5 KiB) Viewed 899 times
- ki5io-self-care.JPG (16.6 KiB) Viewed 899 times
