Need help to switch to MYSQ or not?
PA7RA
Post by PA7RA »
I have Imported my log 125000 qso into LOG4OM but the log is verry slow.
I using as computer this.
Processor Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz
Geïnstalleerd RAM-geheugen 32,0 GB
Type systeem 64-bits besturingssysteem, x64-processor
Editie Windows 11 Home
Versie 22H2
Also have a SSD HD so enough for work with LOG4OM is my opinion.
So i try several time to switch to MySQL but that wil not work here.
But is that better and faster in LOG4OM?
So a lot of questions and sorry fot my bad englisch itry to do the best a can to wxplain my "problem" :D
Tnx Rien, PA7RA
Re: Need help to switch to MYSQ or not?
Yes Mysql should be faster for your database with Log4om
When you say mysql doe s not work for you please describe in detail the problem
PA7RA
Post by PA7RA »
Hello Terry,
Thanks for the support i will try explain what happens.
First I took the manual and I see on page 220 the explanation about the installation of the MySQL by Tom Sp2L
If I follow the links in the user manual I get to the page where I can download mysql 8.20.0.
Then I will download and install the program.
That's where it goes wrong with me, I have a different screen than Tom shows in his description.
This is my screen what I get.
Photo Rien.
And this is Tom's screen.
Photo Tom.
If I can continue with this, this step is already won (lol).
Sorry Terry I'm not really computer tech.
But I try to go through the description step by step.
I hope you can help me further so that I can get started with the beautiful LOG4OM.
Thanks 73" Rien, PA7RA
ei6kw
Post by ei6kw »
Hi Trien,
Did you ever try to disable some hard working functions, e.g. like VOACAP Propagation in Program Configuration? It makes computer's life much easier :)
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
PA7RA
Post by PA7RA »
Hello Slav,
Yes that is disabled already.
Rien, PA7RA
SP2L
Post by SP2L »
Hello Rien.
Came over your post only yesterday.
Did you resolved your issue, please?
From what you showed on your screenshot
it is evident that you downloaded incorrect MySQL installer!!!
To download proper MySQL Installer use this link:
https://dev.mysql.com/downloads/installer/
No need to dig elsewhere, Hi!
Right now, the up to date version is 8.0.35 __NOT__ the one you sent
"8.20.0" which in fact is "8.2.0 Innovation" but is not visible under above link!
In addition see two pictures attached to this post.
Then simply follow verbaim remaining part of my tutorial.
PA7RA wrote: 30 Jul 2023, 06:30 Hello Terry,
Photo Rien.
Photo Tom.
Best regards.
Tom - SP2L
https://www.sp2l.eu
