Flashing Mode & s/r Signal Report
K8TJM
Post by K8TJM »
I made a short video showing the problem.
My setup is Win 10, Yaesu FT-950, US Navigator (now Timewave) interface and I'm using Omni-Rig. It flashes between USB (which the rig is set at) and FT8 via WSJT-X.
Any reason why this is happening?
https://www.dropbox.com/s/wnqfp115lnsh5ko/l4om.mp4?dl=0
Thanks & 73.
Terry / K8TJM
ve3wej
Re: Flashing Mode & s/r Signal Report
Post by ve3wej »
I have been having similar issue ( flashing rst boxes ) and mode ( between ft8 and ft4 )
no firm answers have solved it, other tha reverting back to 2.26.0.0 so something changed.
I think it was to make rst changeable on logging
i think it has to do with band listing, due to the frequency of the radio , it does not know what made is correct
Dave ve3wej / ve3ie
Do you get same flashing condition when you set things up for CW or SSB?
Or ... just the FTxx modes?
Similar comments have been made as Dave has again noted.
We still haven't found it, but are aware and looking.
K8TJM
Post by K8TJM »
KI5IO wrote: 30 Jul 2023, 13:49 Terry,
Hi Nolan,
With only Log4OM running (no WSJT-X or Grid Tracker) I get the flashing when I'm on an FT8 or FT4 frequency. As soon as I dial off these frequencies the flashing goes away.
Hope this helps.
Terry / K8TJM
K8TJM wrote: 30 Jul 2023, 14:41
Hi Nolan,
Hope this helps.
Terry / K8TJM
Tnx for the additional input. I just tried similar. Log4OM "only" connected via USB port to my K3 and dialed to FT8 frequency and I did not experience any 'flashing'.
I'm also using Omnirig and i've attached my CAT settings in Log4OM. Dunno if any button tweak in that setup is affecting the FTxx flashing situation or not.
May be "rig" related as well, but not sure as of yet.
K8TJM
Post by K8TJM »
Hi Nolan,
Tried your settings and still got the flashing.
It's not a show stopper as all I have to do is lock FT8 in l4om.
Stay cool down there Nolan. Crazy wx.
Terry / K8TJM
ZL3GAV
Post by ZL3GAV »
I encounter this in FT4 mode only, noting that if I move the VFO say 10 hertz off the progammed frequency in JTDX the flashing stops.
The Mode dropdown on the main GUI flashes between FT4/FT8. As mentioned by Terry if I lock the FT4 as the mode it fixes the issue.
Using v2.28.0.0, OmniRig, FTDX10.
Gavin
ZL3GAV
Wonder if this is related only to Yaesu rigs ... or at the least "rig specific"?
As noted I'm not experiencing same with my K3 and Terry is also not experiencing same with his SunSDR2 rig either.
We'll keep digging.
KI5IO wrote: 03 Aug 2023, 02:15 Wonder if this is related only to Yaesu rigs ... or at the least "rig specific"?
We'll keep digging.
Not with my Icom radios either
ZL3GAV
Post by ZL3GAV »
G4POP wrote: 03 Aug 2023, 06:28
We'll keep digging.
Possibly radio specific, no issue with Yaesu FT-991A only Yaesu FTDX-10, but was not a problem on earlier Log4OM iterations.
