Flashing Mode & s/r Signal Report
F4BPO
Re: Flashing Mode & s/r Signal Report
Post by F4BPO »
Thanks Terry seems to work now !
73 de F4BPO Greg
ZL3GAV
Post by ZL3GAV »
Hi Terry/Daniele
Thanks for beta 04. On FT4 say on the 18.104 MHz slot in the Log4OM GUI the mode is now showing FT4 on the receive sequence, but on the transmit sequence it changes to FT8, then reverts to FT4 on the next receive sequence etc. Same behaviour on other FT4 designated slots.
My ITU setting is 60, and IARU region 3.
Regards
Gavin
ZL3GAV
ZL3GAV wrote: 18 Aug 2023, 22:31 Hi Terry/Daniele
Regards
Gavin
ZL3GAV
Then I think that may be originating from the JT software, is it only on that band or does it also happen on other FT4 frequencies.
I assume the QSO is saved with the correct mode and its just the visual display that fluctuates?
When we receive the answers to the above we will check futher but its strange that the other beta testers have not experienced this, what radio do you use?
ZL3GAV
Post by ZL3GAV »
G4POP wrote: 19 Aug 2023, 07:11
Regards
Gavin
ZL3GAV
Hi Terry
Thanks, this happens on all FT4 designated slots. The QSO logs correctly, yes it is only the mode display flicks to FT8 on transmit, reverts to FT4 on receive sequence.
Confirming I am using a Yaesu FT-DX10, JT Alert, and JTDX. I tried WSJTX without JT Alert and it has the same issue.
Nothing else in my operating environment has knowingly changed, and the issue for me has only existed with FT4 since the last release version.
Regards
Gavin
ZL3GAV
ZL3GAV
Post by ZL3GAV »
Hi Terry
Further observation just noted, I usually operate at 300 - 500 Hz on the transmit sequence.
However, if I transmit at 1,000 Hz or above it behaves correctly! Select 999 Hz and it flickers to FT8, the plot thickens :o
Gavin
ZL3GAV
ZL3GAV wrote: 19 Aug 2023, 09:03 Hi Terry
Gavin
ZL3GAV
I need exact frequencies and a screen shot of your CAT config in Log4OM ASAP please as we have weeks holiday starting tomorrow
ZL3GAV
Post by ZL3GAV »
G4POP wrote: 19 Aug 2023, 11:19
Gavin
ZL3GAV
Thanks Terry
Note as attached.
Regards
Gavin
ZL3GAV
Log4OM ZL3GAV CAT.png (43.39 KiB) Viewed 1913 times
FT4 frequencies.png (19.33 KiB) Viewed 1913 times
Gavin,
Take a screen clip of your CAT settings in the Log4OM Configuration page as well.
ZL3GAV
Post by ZL3GAV »
KI5IO wrote: 20 Aug 2023, 00:31 Gavin,
Hi Nolan,
As attached, no change in toggling the FT8 checkbox off/on.
Gavin
ZL3GAV
ZL3GAV CAT config.png (67.53 KiB) Viewed 1903 times
Gavin
With Lele now in Wien with his family and me due to more hospitalisation dont expect a response for about a week
