CONFIGURED LOTW INSIDE LO4OM BUT IT ALWAYS STOPS WHEN CLOSING
it9jdr
Post by it9jdr »
hi, I ask for support because I registered on lotw, (I received my credentials and valid certificate) Image
I configured LOG4OM like this:
AFTER configuring the LOTW parameters in LOG4OM, as soon as I close log4om it ALWAYS crashes and ALWAYS stays stuck on this screen. after 10 minutes... it's still on this screen...
I'm always forced to force close LOG4OM with ctrl+alt+can....
ATTENTION!! After 10 attempts and after ALWAYS having to force log4om to close, at a certain point I find myself loaded into my LOTW 791 qso page..... Image
IT ONLY WORKED ONCE... I don't understand why.... Now I put another QSO in the log4om log, but when closed it ALWAYS crashes and no longer sends the log to the LOTW server.....
it9jdr
Re: CONFIGURED LOTW INSIDE LO4OM BUT IT ALWAYS STOPS WHEN CLOSING
Post by it9jdr »
MAYBE I HAVE SOLVED IT...
I'll write the solution here (if there are problems I'll write here again...) so that other radio amateur friends can solve the problem by reading this post:
you ONLY need to check that option:
73 de IT9JDR Antonio :)
