Double on logging
Re: Double on logging
iz6gvc wrote: 12 Nov 2023, 09:35 Hello Mr Terry,
thanks for the suggestion but thw trouble remain.
If I reload the adif with the impostation that you suggested the problem of the dupes remain because remain two applications that send the same infos.
Regards
You must stop one of the other applications sending the same infor but note that in your log the duplicates have a time difference of 30 seconds thats why you set the import to 60 seconds so that it IGNORES those dupes.
But first you must dissable one or the other external programs from sending a QSO!
Dissable JTAlert logiing to Log4OM, just un check the box at top of window
iz6gvc
Post by iz6gvc »
Ok, can you explain one possible way to follow?
I posted some photos, you make an idea of the sw can dupe the infos?
Thanks and sorry.
73s, Camillo
iz6gvc wrote: 12 Nov 2023, 10:51 Ok, can you explain one possible way to follow?
Thanks and sorry.
Your 4th screenshot of jtalert posted 22nd October at 10.40
At top
Check box 'Enable .......'
Un-check that box
iz6gvc
Post by iz6gvc »
Hello, if I disable Logging on Jtalert the QSO not are logged.
73s, Camillo
Well the duoplicate QSO's are coming from one of the other programs so you need to explore deeper.
Its not a Log4OM issue we just receive and log what is sent to us, providing the date, TIME, Call sign, frequency and mode are not duplicated.
iz6gvc
Post by iz6gvc »
Hello, of course Is not and issue of Log4OM.
I hope solve this trouble.
Thanks!
73s, Camillo
