cluster and rig frequency
when I am sending a dx spot to my cluster, I have to enter the frequency. is there an option to track the radio and input frequency based on cat
Dave ve3wej / ve3ie
Re: cluster and rig frequency
Dave,ve3wej wrote: 16 Oct 2024, 20:03 when I am sending a dx spot to my cluster, I have to enter the frequency. is there an option to track the radio and input frequency based on cat
If you are using the "Send Spot" element on the Main UI of Log4OM V2 the information needed is already included.
- SendSpot.png (11.47 KiB) Viewed 1804 times
thanks for the response. can this be added to a future revision
Dave ve3wej / ve3ie
Dave,
The spot feature has been in Log4OM for a couple of years now.
What version are you currently using? I would make sure you are using the most current version.
where is that window located, i have no such window
now v 2.34
now v 2.34
Dave ve3wej / ve3ie
never mind I found it, by mistake. I was using the clust windows send spot, not the mini one
Dave ve3wej / ve3ie
