cluster and rig frequency
ve3wej
Post by ve3wej »
when I am sending a dx spot to my cluster, I have to enter the frequency. is there an option to track the radio and input frequency based on cat
Dave ve3wej / ve3ie
Re: cluster and rig frequency
ve3wej wrote: 16 Oct 2024, 20:03 when I am sending a dx spot to my cluster, I have to enter the frequency. is there an option to track the radio and input frequency based on cat
Dave,
If you are using the "Send Spot" element on the Main UI of Log4OM V2 the information needed is already included.
ve3wej
Post by ve3wej »
thanks for the response. can this be added to a future revision
Dave ve3wej / ve3ie
ve3wej wrote: 07 Nov 2024, 01:53 thanks for the response. can this be added to a future revision
Dave,
The spot feature has been in Log4OM for a couple of years now.
What version are you currently using? I would make sure you are using the most current version.
ve3wej
Post by ve3wej »
where is that window located, i have no such window
now v 2.34
Dave ve3wej / ve3ie
ve3wej
Post by ve3wej »
never mind I found it, by mistake. I was using the clust windows send spot, not the mini one
Dave ve3wej / ve3ie
