ADIF Import
KB3JDL
ADIF Import
Post by KB3JDL »
When I do a contest I log in n1mm. But Log4OM is my daily logbook. I like to export the contacts I make from n1mm and put them in Log4OM and on QRZ.COM. I have Log4OM setup to sync with QRZ.COM, but it appears that when I import the ADIF, it does not sync those entries to QRZ.COM? Is that correct? If so, should I just manually import the ADIF file into QRZ.com also in order to get them in that log?
Thanks for any help!
- Craig
Re: ADIF Import
Craig,
Have you reviewed N1MM Contest Logger Integration on Page 245 of the Log4OM User Guide?
You can have the Q's automatically routed to Log4OM from N1MM.
KB3JDL
Re: ADIF Import
Post by KB3JDL »
Thanks! Good to know.
As far as my question, do imported logs (ADIF) also get sent to the configured online services (ie QRZ)?
Re: ADIF Import
They will if you use the QSL Manager on the ADIF imported Q's.
Not an automatic item for ADIF imports as best I recall.
Only a few key clicks when using the QSL Manager.
