When I do a contest I log in n1mm. But Log4OM is my daily logbook. I like to export the contacts I make from n1mm and put them in Log4OM and on QRZ.COM. I have Log4OM setup to sync with QRZ.COM, but it appears that when I import the ADIF, it does not sync those entries to QRZ.COM? Is that correct? If so, should I just manually import the ADIF file into QRZ.com also in order to get them in that log?
Thanks for any help!
- Craig
ADIF Import
Re: ADIF Import
Craig,
Have you reviewed N1MM Contest Logger Integration on Page 245 of the Log4OM User Guide?
You can have the Q's automatically routed to Log4OM from N1MM.
Re: ADIF Import
Thanks! Good to know.
As far as my question, do imported logs (ADIF) also get sent to the configured online services (ie QRZ)?
Re: ADIF Import
They will if you use the QSL Manager on the ADIF imported Q's.
Not an automatic item for ADIF imports as best I recall.
Only a few key clicks when using the QSL Manager.
