LotW
N4RF
Re: LotW
Post by N4RF »
I will certainly check that.
The paths to the .adif file are correct. I have tried many times with other folders.
Perhaps the most frustrating issue is all QSOs back to 1964 Show LoTw Sent "no" and LoTW received "No". I have 2400 Challenge points and tens of thousands of QSOs. It had everything correct until one day they are all "No".
The latest issue is when I click on Utilities - QSL Manager - Download Confirmations I get the message "this message cannot be downloaded electronically".
I am still uploading via TQSL.
I have become so frustrated that I bought a subscription to Ham Radio Deluxe, but I really don't like it!
Bob N4RF
Pinehurst, NC
N4RF
Re: LotW
Post by N4RF »
Do you see anything wrong? I am guessing the "(C:)\" portion is incorrect.
When I click on File Explorer "OS(C:) - Bob's Stuff - Ham Stuff - Back Up.adif" it takes me to my back up folder and the .adif files.
Here is my Configuration
"Configuration - User Configuration - External Services - LoTW"
User N4RF
Password ************
TQSL exe path (C:)\Bob's Stuff\Ham Stuff\Back Up.adi
Temporary Path (C:)\Bob's Stuff\Ham Stuff\Back Up.adi
Station ID N4RF Pinehurst FM05gf
TQSL Private Pass
My Call (opt) N4RF
Thanks,
Bob N4RF
_______________________________________________
Re: LotW
Bob,
The error message you are getting is because you have selected "QSL" in the Search confirmation (SPECIFIC) window when you first open QSL Manager.
I've noted, at times, that my default selection of LOTW gets flipped/changed to QSL so I try to keep an eye on that, but the moment I tap the Download Confirmation button the error message pops up.
Make sure you select LOTW from the dropdown in the green window. It should be a 'sticky' selection most of the time.
I can't address your Yes / No changes on QSOs when dealing with an ADIF import as there are other options being selected and I've never uploaded/downloaded my logs as a separate ADIF file via tQSL. I've just never had an issue with the QSL Manager functionality so didn't have to pursue that.
Have your watched the 3 YouTube videos that Terry did about setting up all the many settings for uploads/downloads that also involve LOTW? The User Guide has a good and detailed description of setting up the Confirmations ... starting on Page 116.
ve3wej
Re: LotW
Post by ve3wej »
'C:\users\N4RF\AppData\Roaming\Log4OM/\temp' is denied.
is this what you typed or is it the actual error? the path is invalid log4om/\temp i think one slash too many maybe that is the error. check your path
Dave ve3wej / ve3ie
N4RF
Re: LotW
Post by N4RF »
Many, if not most are missing the Grid Square. It was there before and is no longer. It takes forever to insert them manually. Other than that, everything seems normal. It worked for years and then quit working about the time I noticed the missing Grid Squares.
I can download with no problems now, I just can't upload unless I do it via TQSL.
My TQSL exe path is:
Is that correct? I wonder about the (C:)\ element...
Bob N4RF
N4RF
Re: LotW
Post by N4RF »
I changed the green box to LoTW. I can download from LoTW, but I can't upload.
There is some progress now. I am getting a few "received" now in QSL manager. How do I
reconcile Log4OM .adi files with LoTW .adi files? I want to populate the sent and rcvd QSOs.
When I try to upload selected QSOs, I get the message "TQSL file not found in this path: (C):\Bob's Stuff\Ham Stuff\Back Up.adi.Exiting
LoTW END"
When I go to that path, my most current .adi back up is there.
Bob N4RF
Re: LotW
N4RF wrote: 01 Jan 2025, 15:15 I changed the green box to LoTW. I can download from LoTW, but I can't upload.
LoTW END"
Bob N4RF
Firstly you need to watch the three Youtube tutorials, Confirmation 1, 2 & 3
The TQSL path is the path to the TQSL application like C:\Program Files (x86)\TrustedQSL it is not a path to an adi file.
If you watch the videos and check the user guide it is all explained in full
