LOTW UPLOAD QUESTION
How/when will you know when a QSO has been uploaded to LOTW by LO4OM. I generally know it has been uploaded in QRZ when it becomes highlighted in green. For some reason it doesn't appear they are being uploaded by LOG4OM and I have to manually upload them via QRZ. I've synced the "confirmation" tab with the "external services" tab for LOTW and the PWs appear correct. Any suggestions. Thanks, Dan K2DJL 73
Re: LOTW UPLOAD QUESTION
Also, when I try to change anything in the "confirmations" tab, it automatically reverts back to "no" in sent and received tabs. Thanks again, Dan K2DJL 73
Upload to QRZ is via the API key make sure that you have that correct
QRZ API key is correct
You did do the save using the small black floppy on confirmations page, followed by save and apply didnt you?K2DJL wrote: 13 Feb 2025, 21:38 Also, when I try to change anything in the "confirmations" tab, it automatically reverts back to "no" in sent and received tabs. Thanks again, Dan K2DJL 73
Clearly this is a local issue because it seems its working for other users including me.
Try copy and pasting the API code into the External sevices field, could be a typo or miss click on copy
Hi Terry:
Thanks for the help. I think my saving sequence with the floppy click and "save and apply" was off. It is uploading to LOTW now "Automatic upload on application close". For some reason I thought that QRZ would show the upload without having to click the "Import from LOTW" button in QRZ. Anyway, thanks again and best 73s. Dan K2DJL
