Good morning OM,
I'm doing the Marconi Award and I have log4om connected via UDP to the HamAward platform. All Log4OM QSOs are transferred.
Last night, probably due to a network problem, some QSOs did not pass through. Is it possible to select one or more QSOs from the "Recent QSOs" and resend them via outbound UDP?
Resend QSO via UDP outbound
Max IK0TIX
Max IK0TIX
Re: Resend QSO via UDP outbound
No you need to export them as an ADIF and import into the other program
Many thanks Terry, I had imagined it, the problem is that HamAward does not allow the import of the ADIF by the user, I have to send the file to the administrator. I will Survive
Max IK0TIX
Max IK0TIX
Porta UDP per HaamAward
Buongiorno e buona domenica
Qualè la porta UDP che collega Log4Om a HAmAward ?
In SETUP/CONNECTIONS/ nella parte destra devi semplicemente mettere
N. di porta 12060
Nome a scelta tipo HAMAWARD
Attivare Flag Broadcast
e aggiungere con il + verde
Ci sarai già arrivato ma lo metto per altri.
N. di porta 12060
