What the heck - another suggestion
K2GAV
Post by K2GAV »
I really like the Main (F6) screen when running WSJT-X and Log4OM at the same time. In this configuration Log4OM is there mostly to take new contact logging information from WSJT-X. I have SJT set up to only send the logging information after I say OK to the entry SJT is about to send. So, I'm often switching to Recent QSO's (F7) to be sure it enters correctly.
It would be fantastic if Log4OM provided the option of a split screen between Main and Recent QSOs, perhaps with the ability to locate the horizontal split line between the two screens. I'd have most of the screen showing Main, with a few lines of the log peeking through above or below the Main screen.
Again, I'm likely asking for too much.
Thanks for all your work on this fantastic logging program!
Best wishes,
Ted Szypulski
K2GAV
Kenwood TS-990, Elecraft KPA-1500
Re: What the heck - another suggestion
Just detatch the recent QSO window and possition as required, see below
Screenshot 2024-11-30 234255 new.png (100.05 KiB) Viewed 3721 times
K2GAV
Post by K2GAV »
Just what I want, but I'm trying to figure out how to detach the F7 window. I'll keep looking.
Ted
K2GAV
Best wishes,
Ted Szypulski
K2GAV
K2GAV wrote: 28 Mar 2025, 18:57 Just what I want, but I'm trying to figure out how to detach the F7 window. I'll keep looking.
Ted
K2GAV
View/QSO grid
K2GAV
Post by K2GAV »
Okay, I figured out that the two overlapping rectangles at the bottom of the F7 screen mean detach the window. And, I also figured out that you squeezed the rest of the Log4OM window by taking Log4OM out of full screen mode and putting it in Windowed mode. Then I can position the two windows for the type of display needed.
Thanks for the clue on how to achieve this.
Ted
K2GAV
Best wishes,
Ted Szypulski
K2GAV
K2GAV
Post by K2GAV »
Okay, now I know View/QSO Grid also detaches the F7 window.
Thanks.
Best wishes,
Ted Szypulski
K2GAV
K2GAV
Post by K2GAV »
Unless I'm doing something wrong, it appears that the detached QSO grid settings for columns, appearance, size and position are not remembered by Log4OM when you exit. I have to set all this up again each time I open Log4OM.
However, once it's set up the way I want it, it does fulfill my desires.
Best wishes,
Ted Szypulski
K2GAV
K2GAV
Post by K2GAV »
Nevermind, now it is remembering those paramenters. I guess I must have exited or closed something incorrectly the first time.
Best wishes,
Ted Szypulski
K2GAV
