Using V2.35.1.0 I've tried to integrate a new club in the "Club membership list" feature.
Here is a few additions to the feature I would like to suggest:
- see the membership number for a user defined club immediately when entering a callsign
- be able to use the "Extended" form for a QSO, right now the user defined club is not visible
- be able to use the club information in the awards manager to define a new award
Frank
Clubs support
Re: Clubs support
Many of us belong to more than one club, which one should be displayed, plus this adds to processing times!dl2cc wrote: 07 Apr 2025, 17:36 - see the membership number for a user defined club immediately when entering a callsign
Extend which form?- be able to use the "Extended" form for a QSO, right now the user defined club is not visible
Be patient,we only just added the membership feature, it takes time to extend each feature!- be able to use the club information in the awards manager to define a new award
Frank
[/quote]
Re: Clubs support
Extend which form?
-> there is an "Extended (F5)" form
-> this already implemented, you can choose the clubs to be searched already
Extend which form?
Re: Clubs support
Ah! you refer to the Extended Tab on input window.
Well seems to work for me or am I missing something?
Shows he is a member in the messages pane and displays his number in the F5 tab
Re: Clubs support
Interesting, no - my F5 tab doesn't allow me to select my user defined club.
The F5 tab shows different clubs than the ons I see in the settings "Software - Info Providers - Club Membership"
So maybe something is wrong with my setup?
Re: Clubs support
Frank,
I've only selected the SKCC club in my configuration to follow. Thus that is the one that will be visible in the Main UI data window. Also that is the one that will appear in my Extended (F5) dropdown fillin.
Hope this might help your situation for a better understanding.
- club-skcc-selected.png (16.51 KiB) Viewed 4351 times
- club-drop-down.png (17.54 KiB) Viewed 4351 times
Re: Clubs support
OK, thanks - I suppose that's how it should be. However, it's not in my case.
Re: Clubs support
Frank,dl2cc wrote: 13 Apr 2025, 20:13 OK, thanks - I suppose that's how it should be. However, it's not in my case.
Can you provide an image of your Club Membership settings in the Configuration like I did?
Re: Clubs support
Where did you save te club list to?dl2cc wrote: 13 Apr 2025, 20:13 OK, thanks - I suppose that's how it should be. However, it's not in my case.
Did you update the clublist resources file?
Did you click the small floppy disk 'save' icon before Save and apply?
Did you restart Log4OM?
Re: Clubs support
Sorry for the delay, here are the screenshots of the settings and of the extended window, I hope I am doing it right
- ExtendedF5.png (45.31 KiB) Viewed 695 times
- clubs.png (86.69 KiB) Viewed 695 times
