Connecting LOG4OM to FLEX 6300
AH6TX
Post by AH6TX »
I have your program working on my TS-480HX just fine. I just purchased and installed a flex6300. The procedure to work with CAT systems for the FLEX is to first install SmartSDR CAT. In doing so the program identified the following:
to connect to com port 4. My next step was to load OmniRig and make the COM PORT 4 into RIG2. The only problem is you don't have a selection for the FLEX 6300. I spoke with Flex and they suggested either TS-2000 or PowerSDR, which is there old software. In either case I could not get it to work.
Please advise what I need to do to connect your software to my FLEX.
Howard Krawitz
AH6TX
gvm920@gmail.com
661-821-0923
ik2egl
Re: Connecting LOG4OM to FLEX 6300
Post by ik2egl »
ciao Howard ,
I did a check and based on the information provided all seems to be fine.
I have only 2 questions:
1) why do you use RIG2 instead of RIG1 ?
2) do you have other vitual port emulator working in the same time with smartcat ? (you can also check in system resource if there are other com port available not defined by the smartcat ).
try also to create a new "dedicated" port in smartcat (com5) and try to use COM5 instead of com4
keep us informed !
73 de Don IK2EGL
AH6TX
Post by AH6TX »
Not sure how you would create a new port. I used rig2 until I am sure I am going to keep the 6300.
I don't have anything else running. Smartsdr cat say to use port 4.
Which interface should i use TS-2000 or what?
Your help is appreciated.
Howard
AH6TX
ik2egl
Post by ik2egl »
the ts2000 is the right one.
check also the manual of log4om where you can find
a specific paraghaph I wrote on flex signature integration
let me know
73 de Don IK2EGL
AH6TX
Post by AH6TX »
Thanks for your info. I found the info in the manual, however the SMART CAT indicates to go to COM4. How can I change that for 5 as it indicates in the manual? Smart Cat has some options but I don't know how to use them. Please advise.
Howard
AH6TX
ik2egl
Post by ik2egl »
enter in the smartcat menu and create a new port as dedicated (not shared, not ptt).
have a look at smartcat manual as it is fully explained
73 de Don IK2EGL
AH6TX
Post by AH6TX »
have looked for the manual and can't find it. I have smartsdr cat ver 1.2.8.0. If you have a copy can you send it to me. GVM920@GMAIL.COM
Howard
ik2egl
Post by ik2egl »
manual sent !
:D
73 de Don IK2EGL
AH6TX wrote:have looked for the manual and can't find it. I have smartsdr cat ver 1.2.8.0. If you have a copy can you send it to me. GVM920@GMAIL.COM
Howard
In Log4om go to help/help/English - Force update then view the downloaded help file
Alternatively the manual download link is just below the link you used to download the program
Page 201 refers
ik2egl
Post by ik2egl »
hi Howard
was you able to do make 6300 integrating with log4om ?
if you need support I am available in the weekend also on skype
let me know :)
73 de Don IK2EGL
