- bandgrey.JPG (84.31 KiB) Viewed 3629 times
IW3HMH wrote:
The only thing you should do, in that case, is to manually set the band. Then Log4OM will save your QSO.
if bandplan has a gap in that frequency area (can be an error, happens) Log4OM is not able to identify band because the reported frequency is not "recognized".
Setting band manually will allow you to log everything, everywhere, even out of band.
I thought that would be a good solution, but I must have some setting in background preventing me.
The ability to manually set the band is greyed out on my screen --- see attachment.
