Rig Changes LSB to USB when using Log4OM
m0bob
Post by m0bob »
I am using a Yaesu FT920 with Log4OM and I've noticed that since using this log, LSB changes to USB on 40m & 80m. Any suggestions please?
Thanks,
Bob.
M0BOB.
Re: Rig Changes LSB to USB when using Log4OM
m0bob wrote:I am using a Yaesu FT920 with Log4OM and I've noticed that since using this log, LSB changes to USB on 40m & 80m. Any suggestions please?
Thanks,
Bob.
M0BOB.
Bob,
What are you using Hamlib or Omnirig?
Have you set your region correctly in the options/station details?
What part of the 40 and 80 meter bands does this happen on?
How have you got the cluster settings set - see screen shot below
m0bob
Post by m0bob »
Thanks Terry, I am using Omnirig and I will check the settings later when I return home.
Bob.
M0BOB.
m0bob
Post by m0bob »
I had a look and the settings seem ok. I am now beginning to think the problem may be with the rig.
Bob,
Does not seem like a rig or interface issue!
Please check that you have "Region 1" selected as in the image below, if not set it to Region 1 and then save the configuration and restart the software
Does the mode change to USB no mater what part of the 40/80 meter bands it is changed to?
i don´t think that it´s a problem with a "wrong" bandplan setting. In all 3 regions we have the same rule. LSB from 10 MHz below and USB from 10 MHz above. The reason is that commercial or military stations using USB below 10 and LSB above 10 MHz ....
Maybe there´s a "reverse" button pressed at the transceiver or in it´s menu (i don´t know his Rig) or a reverse in the software ??
I forgot to ask the most important question!
Is the correct mode selected for all of the other bands?
