Order of Sent and received reports in new QSO
vk1da
Re: Order of Sent and received reports in new QSO
Post by vk1da »
That change would be very welcome. It would match every one of my paper logs, all contest logs, all my spreadsheets AND would match the order of data on screens and reports from your software. Thank you so much.
Andrew
Andrew VK1DA Canberra Australia QF44MO VK2UH Yass QF45LD
vk1da
Post by vk1da »
The same sequence change would be needed on the popup screen displayed for editing a previously recorded contact. It is currently presented in the Received, Sent order, so if the order of those fields is changed on the initial QSO screen it would be consistent to update that popup editing screen too.
VK5PL
Post by VK5PL »
+1 for Sent on the left
David
VK5PL
David,
As Daniele said in an earlier posting we have changed it
Sent is now on the left
Received is now on the right
You can change the column order/layout in the recent QSO's F8 tab by using the layout choice at the bottom of that window
