saving main screen layout, and cluster modes
G1YBB
Post by G1YBB »
I like to drag the cluster panel size over so I can see more of the location text, and tweak other panel sizes within the main window.
Can my sizes be saved?
As they revert to standard every time.
And when the cluster is running, I turn off CW and digital to just see the phone spots. Can that be saved too?
VE3VEE
Re: saving main screen layout, and cluster modes
Post by VE3VEE »
Hi G1YBB,
Yes:
73 Marvin VE3VEE
G1YBB
Post by G1YBB »
VE3VEE wrote:Hi G1YBB,
Yes:
73 Marvin VE3VEE
Hi Marvin.
Eventually found that panel but for me it didn't work. :-(
Next start of the app back to the as installed layout.
VE3VEE
Post by VE3VEE »
Yes, but my answer was not in relation to the layout. I was answering your question about the CW/DIGI/PHONE filters:
G1YBB
Post by G1YBB »
VE3VEE wrote:Yes, but my answer was not in relation to the layout. I was answering your question about the CW/DIGI/PHONE filters:
Ah I get you now. I never use that F9 screen, I like the map view.
These are the ones I wanted to stick unselected:
VE3VEE
Post by VE3VEE »
Hmm, if you only operate Phone, perhaps there's a way to fool LOG4OM into doing what you want on a more permanent bases by editing some configuration file to tell LOG4OM to look only within the SSB portion of the bands... I'm not sure, but perhaps there's a way... or simply start using the main cluster window and switch to map view only occasionally when you really need it ;-) I know the map is pretty, but the main cluster window is more useful ;-)
73 Marvin VE3VEE
Or send a filter to you chosen cluster to not send CW or data spots (accept phone only) :D
G1YBB
Post by G1YBB »
G4POP wrote:Or send a filter to you chosen cluster to not send CW or data spots (accept phone only) :D
Ah that could be an idea.
What about saving the panel layout of main screen? Can it be done?
G1YBB wrote:What about saving the panel layout of main screen? Can it be done?
No it cannot
VE3VEE
Post by VE3VEE »
Perhaps if it were possible to DETACH the main cluster window (F9) and/or detach the map (F7) you could keep one of them on the second computer monitor and the problem could be solved that way. I know I would love to be able to do that! I'd love to see both the main cluster window AND the map at the same time.
73 Marvin VE3VEE
