CAT survey. Please vote.
What software are you using for RIG integration (CAT) in Log4OM
OMNIRIG ONLY (HAMLIB doesn't works)
9
15%
OMNIRIG
46
78%
HAMLIB ONLY (OMNIRIG doesn't work)
3
5%
HAMLIB
1
2%
NO CAT
0
No votes
Total votes: 59
VK7XX
Re: CAT survey. Please vote.
Post by VK7XX »
IW3HMH wrote: I've plans and a working prototype of a "log4om CAT" (some text deliberately omitted)
excellent !!!!!!!! :D
J85K
Post by J85K »
FYI -- Using Yaesu FT 2000 transceiver. No other rig at tested.
-- OMNIRIG -- assumed that poll associated my post comment .....
Regards,
Kumar_J85K
J85K wrote:FYI -- Using Yaesu FT 2000 transceiver. No other rig at tested.
Regards,
Kumar_J85K
Er! Omnirig or Hamlib?
WQ4A
Post by WQ4A »
OmniRig!
Paul
WQ4A
wa6gxq
Post by wa6gxq »
I have two rigs ic-746 non pro. and ic-707. I have the ic-746 working with omnirig. the ic-707 is not covered in omnirig. In hamlib the rig is covered, but will not work. The ic-707 Works fine with HRD. I use the ic-707 a fair amount. Is there any help with this isuue?? I don't think ham is a reliable product. please help.. thanks
Did you try any of the other Omnirig selections for the 707 many of the Yaesu set ups will work with others
G1YBB
Post by G1YBB »
As a new user I went for Omnirig (I think it mentioned in the user manual it may be the better option) and once I tweaked the baud rate in the rig from it's default, is working lovely.
No reason to change, and I have recommended a friend use it also, after recommending Log4OM to him and him loving it too.
Omnirig on FT-897D
VE3VEE
Post by VE3VEE »
I have a remote QTH with TS-480. I used to use Omnirig, but at one point it stopped working and after a lengthy experimenting with it I gave up and switched to Hamlib.
I don't recall what exactly it was that caused my Omnirig issue. It might have been an addition of a new hardware (at the remote site) and/or new software (at home), but yes, at one point I was no longer able to use LOG4OM with Omnirig.
I'm sure this post is not very helpful... sorry... if I do recall what my issue was, I will post details.
73 Marvin VE3VEE
wa6gxq
Post by wa6gxq »
G4POP wrote:Did you try any of the other Omnirig selections for the 707 many of the Yaesu set ups will work with others
I tried other icom models, but no yaesu. i will try it. sorry about the late response. thanks
wa6gxq
Post by wa6gxq »
Tried all Yaesu interfaces. no success.
