discrepancy for K2GT
Re: discrepancy for K2GT
IU3CYV wrote: 19 Jul 2020, 17:54 I was sure that all the dxcc were contained in that file.
and in which log4om file has the information of all the dxcc?
It contains the BASIC DXCC info but does not account for exceptions to the BASIC prefix rules, those exceptions are derived from the Clublog EXCEPTIONS file and the other stations entries on on line lookup facilities
You can change the order if you wish!
IU3CYV
Post by IU3CYV »
now I understand how log4om works so it needs online db to be more precise.
Thank you
73 de Tiziano IU3CYV :roll:
(old callsign IW7EFC)
N6VH
Post by N6VH »
Terry,
Is the Clublog Exception list in the clublog.xml file? If so, mine doesn't have anything in it except for this (see attached picture):
I had just done an "Update Resources/Clublog" to check, and it's still the same. The file is only 1 kb. The clublog.xml file that I have in Log4OM v1 is 12798 kb.
I am using Log4OM 2.8.0.0 and Win 10 1909.
Jim N6VH
N6VH
Post by N6VH »
Terry,
I just tried doing a clublog update with Log4OM v1. The file that was in the configuration folder for v1 was dated 4/22/2020. After the update, it still has the same date, even though I got the message from Log4OM v1 that the file was updated. I then moved the clublog file from the folder and did the update again (still using v1). The file did not get placed in the config folder. I then went to v2, moved the clublog file from the config folder, and did the update. In this case, the new file was placed in the folder, but still only 1 kb. There might be two different issues at work here, but the important one (to me, at least) is that the file in v2 is basically empty.
Jim N6VH
N6VH
Post by N6VH »
Terry,
That was fast work. I just saw your message about the Clublog issue. I made the correction, and it worked fine. Keep up the great work.
Jim N6VH
