frequencies of the 2 VFOs
Re: frequencies of the 2 VFOs
KD0ZV wrote: 21 Apr 2022, 11:25 Well if I knew what SDC was, I would try it :D
Sorry just realised that SDC is a SunSDR interface
iz2rlo wrote: 21 Apr 2022, 13:29 Thank you guys for your help,
if the problem is lo4om let's hope they fix it,
let's see if someone has solved
73 Cris iz2rlo
Cris, you might consider HamLib.
Not sure if you are running slicemaster for the flex but its a great program. There is a Log4OM readme file in the zip file that shows you how to connect the Flex to Log4OM with HamLib. It will make both VFOs work and Log4OM will log whatever slice is set to TX.
My only complaint is you need to start the programs in order. Flex, SliceMaster and then Log4om.
2022-04-22_06-24-32 (Medium).jpg (173.75 KiB) Viewed 2460 times
iz2rlo
Post by iz2rlo »
hi Rich
thanks for your help, I have to understand how HamLib works many thanks 73 Iz2rlo Cris
iz2rlo
Post by iz2rlo »
can you tell me the settings you made in log4om with hamlib
thanks
Have you downloaded and installed SliceMaster?
In my setup that's a required component. There is a Log4OM file in his installation zip file giving step by step instructions.
iz2rlo
Post by iz2rlo »
hi Rich
yes i have downloaded slice Master now all ok it works THANK YOU for helping me
You are welcome. Hamlib works better than OmniRig in my opinion but as I said needs started up in the proper order to get to work.
ve3wej
Post by ve3wej »
I notice that 'slice b' was not change to be B, but was also A
Dave ve3wej / ve3ie
ve3wej
Post by ve3wej »
mine works, so not log4om issue check smartcat again
Dave ve3wej / ve3ie
