Yes, selecing Save & Apply does close the config dialog box.
As a problem solving test, I tried to also Save & Apply under User Configuration tab in order to lock in the default database, but it didn't work.
I tried your suggestion: File/Open/New Database, and it worked to select a new database. however, when I closed and reopened Log4OM, it reverted back to old defunct database.
It's odd. I mentioned I also Uninstalled Log4OM and did clean reinstall, yet this old defunct database (and all old settings) persist.
Charlie
Database default upon startup
Re: Database default upon startup
Did you install to default locations or have you installed somewhere else?
Yes. I uninstalled, and reinstalled in new folder on C: drive. The new install includes all of my previous settings including the defunct database.
It must be a user config file (or something) that is not being removed during uninstallation. I'm running Windows 11.
thanks
Charlie
thanks
Charlie
n8dd wrote: 12 Jan 2023, 23:55 Yes. I uninstalled, and reinstalled in new folder on C: drive. The new install includes all of my previous settings including the defunct database.
thanks
Charlie
No please let the program install in the default location which is the Program files x86 folder, you dont need to change anything just accept the defaults dont install in any other folders on C drive
I've done that, too. Does not change the default database that keeps populating the settings.
ARe there user config files that remain following uninstall?
Charlie
Charlie
Yes in the C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2 folder if you installed to default locationsn8dd wrote: 13 Jan 2023, 17:25 I've done that, too. Does not change the default database that keeps populating the settings.
Charlie
Many thanks. Once I deleted that user config file and reinstalled everything worked.
Charlie
N8DD
Charlie
N8DD
