160M "Out of Band"
K0HB
Re: 160M "Out of Band"
Post by K0HB »
G4POP wrote:
G4POP wrote:Tomorrow I will modify the r2 bandplan and post it here for you
Zipped revised band plan, without the gap, here for you to use
Please note that you can modify this file easily using "Notepad"
Thank you. The revised bandplan works well.
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
K0HB
Post by K0HB »
IW3HMH wrote: The only thing you should do, in that case, is to manually set the band. Then Log4OM will save your QSO.
if bandplan has a gap in that frequency area (can be an error, happens) Log4OM is not able to identify band because the reported frequency is not "recognized".
Setting band manually will allow you to log everything, everywhere, even out of band.
I thought that would be a good solution, but I must have some setting in background preventing me.
The ability to manually set the band is greyed out on my screen --- see attachment.
DE Hans, KØHB
This happens when CAT is active.
I should check what happens if "out of band" sign appears. This field should unlock, but i'm not sure if that happens.
KD5UVV
Post by KD5UVV »
Just wanted to say Thanks Terry as this helped me out also. Great work!!! Thanks again
Dale
