Clubs support
Re: Clubs support
G4POP wrote: 13 Apr 2025, 23:13
dl2cc wrote: 13 Apr 2025, 20:13 OK, thanks - I suppose that's how it should be. However, it's not in my case.
Where did you save te club list to?
Did you update the clublist resources file?
Did you click the small floppy disk 'save' icon before Save and apply?
Did you restart Log4OM?
If you answer my questions I might be ablt to assist you
dl2cc
Re: Clubs support
Post by dl2cc »
Yes you're right, sorry for late reply.
-> file on harddisk
-> do you mean Settings - Update Resources - club membership data ? Yes
-> yes
As you can see from my screenshots, the clubs shown in the extended window are different from the ones selected in the settings window
Re: Clubs support
dl2cc wrote: 15 May 2025, 07:16 Yes you're right, sorry for late reply.
-> file on harddisk
-> yes
The file should be stored in C:\.....\appdata\roaming\Log4OM2
Did you add the club to the settings/resources editor/clublist.txt file? and save it
Email me your csv file of members that you used
dl2cc
Re: Clubs support
Post by dl2cc »
I've attached the FOC club members file in this post.
I now have stored it in the C:\.....\appdata\roaming\Log4OM2 as you've suggested.
-> I've now done that and can confirm that FOC now indeed shows up in the Extended Window, very good.
However, as soon as I QSO the next callsign, the "Contact Club & Assoc's" dropdown is wiped and thus no club info is shown.
The orange [FOC] in the QSO entry window shows for some members, but not for all.
For example, it shows for VE3EJ, but not for DJ6SI.
TNX, 73
Frank
focCallHistory.txt
(19.99 KiB) Downloaded 12 times
Re: Clubs support
dl2cc wrote: 15 May 2025, 13:48 I've attached the FOC club members file in this post.
TNX, 73
Frank
Your file is not going to work it has many duplicate membership numbers, each member must have a UNIQUE membership number
Also there are some lines with multiple call signs and superflous data
Log4OM expects and searches for the unique call sign entered and expects there to only be one membership number attached to that call. As an example there are eight call signs all with the number 1708
Screenshot 2025-05-15 172848.png (14.9 KiB) Viewed 294 times
dl2cc
Re: Clubs support
Post by dl2cc »
thanks for analyzing, well yes that is by design - as many members hold different callsigns and they are all mentioned in the file.
I'll try to make a file with only the primary callsigns.
