the Automatic upload works fine for me no problem
double check your HRDlog upload code is correct (from the external services menu)
emmanuel
HRDLog On AIR status
Re: HRDLog On AIR status
EmmanuelF4WBL wrote: 10 Apr 2020, 15:06 Hello
emmanuel
Thanks for the advice.
My upload code is correct. I actually had it resent to me via HRD just in case, I than re entered it and rebooted lg4om and it still did not work. I will try and change the sent status to NO as others mentioned.
Mike-W2MJP
Mike-W2MJP
If the sent HRDLog status of the QSO's you want to upload is set to yes then Log4om considers them already uploaded and will not upload them againW2MJP wrote: 10 Apr 2020, 17:32EmmanuelF4WBL wrote: 10 Apr 2020, 15:06 Hello
emmanuel
Hi TerryG4POP wrote: 10 Apr 2020, 17:43If the sent HRDLog status of the QSO's you want to upload is set to yes then Log4om considers them already uploaded and will not upload them againW2MJP wrote: 10 Apr 2020, 17:32EmmanuelF4WBL wrote: 10 Apr 2020, 15:06 Hello
emmanuel
Thank you guys for the heads up. I changed it back to Send=NO and All is working fine again. I guess I had switched at one point hence the reason it stopped working. Stay safe.
Mike-W2MJP
Mike-W2MJP
I am using Log4om V2 2.27.1.0
Settings in erxternal datas are made to automatic swich HRDLOG ON AIR
CAT is working FTDX 5000 MP and USB interface SCU 17
In HRD i can see i am online but wrong Frequency, always 7000 CW
I copied the Scriped and copy into QRZ. There i see the same.
I wonder what is wrong. Thank you in advance for any suggestions
- QRZ.JPG (31.05 KiB) Viewed 877 times
- HRD.JPG (23.33 KiB) Viewed 877 times
