Page 3 of 3
Re: HRDLog On AIR status
Posted: 10 Apr 2020, 15:06
by F4WBL
the Automatic upload works fine for me no problem
double check your HRDlog upload code is correct (from the external services menu)
emmanuel
Posted: 10 Apr 2020, 17:32
by W2MJP
F4WBL wrote: 10 Apr 2020, 15:06
emmanuel
Emmanuel
Thanks for the advice.
My upload code is correct. I actually had it resent to me via HRD just in case, I than re entered it and rebooted lg4om and it still did not work. I will try and change the sent status to NO as others mentioned.
Posted: 10 Apr 2020, 17:43
W2MJP wrote: 10 Apr 2020, 17:32
emmanuel
Emmanuel
If the sent HRDLog status of the QSO's you want to upload is set to yes then Log4om considers them already uploaded and will not upload them again
Posted: 10 Apr 2020, 21:07
by W2MJP
G4POP wrote: 10 Apr 2020, 17:43
emmanuel
Emmanuel
Hi Terry
Thank you guys for the heads up. I changed it back to Send=NO and All is working fine again. I guess I had switched at one point hence the reason it stopped working. Stay safe.
Posted: 26 May 2023, 07:14
by DJ9UN
I am using Log4om V2 2.27.1.0
Settings in erxternal datas are made to automatic swich HRDLOG ON AIR
CAT is working FTDX 5000 MP and USB interface SCU 17
In HRD i can see i am online but wrong Frequency, always 7000 CW
I copied the Scriped and copy into QRZ. There i see the same.
I wonder what is wrong. Thank you in advance for any suggestions
