Custom Highlights
VE4DXR
Custom Highlights
Post by VE4DXR »
I am using V.1.24.0.0. there no award programs showing in the Regular Expression Editor. How do I add any awards and where do i find the text to fill the large box of this window for programs such as IOTA, SOTA, NPOTA, World Flora Fauna. 73 Lee - VE4DXR
Re: Custom Highlights
In your C:\Users\YOUR USER NAME\AppData\Roaming\LogOM folder delete these two files and then restart Log4om
having the same problem here as i have seen today. No highligts when IOTA, SOTA or other awards are spotted. I have deleted both files and restarted Log4OM but no change. No filters in the Regular Expression Editor ... :( :(
DF5WW wrote:Hi Terry,
Did you try a new install?
VE4DXR
Post by VE4DXR »
Deleting these 2 files and restarting LOG4OM did not fix the problem. Still no rules for IOTA NPOTA etc. Lee
VE4DXR wrote:Deleting these 2 files and restarting LOG4OM did not fix the problem. Still no rules for IOTA NPOTA etc. Lee
Did you try a fresh install after deleting the files?
Try the attached
regexpfilters_Cluster_user.zip
(2.48 KiB) Downloaded 366 times
tried a new installation (the 4rth since new Beta is out) and both files are have 1 KB and the REE window is empty as you see in my attached pic in the post above ..... Tried your files from the ZIP, unpacked it and copied the files in the config folder. Both files show 3 KB. After restarting Log4OM the file "regexpfilters_Cluster_user" is back to 1 KB and the editor window is empty .... No award spots will be highlighted :( :(
Works now with your files .... My mistake, i copied them to the configuration folder whlie Log4OM was running. After the restart no higlighted cluster spots (IOTA, SOTA e.g.). Now i´ve stopped Log4OM, copied your files into the config folder and start Log4OM again. All fine now. Cluster award hoghlits are working ....
:o :o
