Log4OM stops after booting
EA4DKJ
Post by EA4DKJ »
Hi all,
When I boot the program this evening, it stopped just after completing the booting process. Any restart trial failed repeatedly.
Finally, I decided to uninstall and reinstall it, but no changes: no way to keep running after booting.
I cannot attach the log file, as it is 281 KB; may I have an email address to forward it?
Many thanks in advance.
Greetings,
Alfonso EA4DKJ
Log4OMCommunicator_log_20160330.txt
(56.88 KiB) Downloaded 200 times
Re: Log4OM stops after booting
Please reinstall but select Run as administrator by right clicking on the install file
EA4DKJ
Post by EA4DKJ »
I am using XP and, if I am not wrong, on a user profile as Administrator. In fact, I have been using the program for several weeks with no issues. Until yesterday evening...
Amazingly, this morning, before leaving to work, I run the program twice and it worked, apparently, properly (I did not have the chance to keep it open for long and see). But I checked that in the logging record there were no ERROR lines as yesterday.
Any ideas about yesterday problems? I am attaching the recorded lines of the last trial yesterday:
2016-03-30 22:03:10.9560 INFO: LogWriter: #################################################################################################################
2016-03-30 22:03:10.9716 INFO: LogWriter: ########################################## PROGRAM STARTED ######################################################
2016-03-30 22:03:10.9716 INFO: LogWriter: #################################################################################################################
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: ############## USER IS ADMINISTRATOR ##############
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Program started
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Log4OM folder set: H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Log4OM backup folder set: H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\Backup\
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Log4OM hamlib folder set: H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\hamlib\
2016-03-30 22:03:10.9716 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Log4OM version: 1.24.0.0
2016-03-30 22:03:10.9716 INFO: FileManagement: CONFIG begin load
2016-03-30 22:03:11.0028 INFO: FileManagement: CONFIG load completed
2016-03-30 22:03:11.0028 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Executing preload auto-start sequence
2016-03-30 22:03:11.0028 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Preload auto-start sequence completed
2016-03-30 22:03:11.0185 INFO: FileManagement: File Management begin load localization
2016-03-30 22:03:11.1747 INFO: FileManagement: File Management localization loaded
2016-03-30 22:03:11.1903 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: BAND LIST load start
2016-03-30 22:03:11.1903 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: BAND LIST load completed
2016-03-30 22:03:11.1903 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: CONTEST load start
2016-03-30 22:03:11.1903 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: CONTEST load completed
2016-03-30 22:03:11.1903 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: MODES load start
2016-03-30 22:03:11.2528 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: MODES load completed
2016-03-30 22:03:11.2528 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: SATELLITES load started
2016-03-30 22:03:11.2528 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: SATELLITES load completed
2016-03-30 22:03:11.2528 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Loading Awards list
2016-03-30 22:03:11.2528 INFO: FileManagement: AWARD LIST begin load
2016-03-30 22:03:11.4247 INFO: FileManagement: AWARD LIST load completed
2016-03-30 22:03:11.4403 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Awards list loaded
2016-03-30 22:03:11.4403 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Loading activations list
2016-03-30 22:03:11.4403 INFO: ActivationManagement: GetActivationList started
2016-03-30 22:03:11.5653 INFO: ActivationManagement: GetActivationList completed
2016-03-30 22:03:11.5653 INFO: #=qcoFPcEBAlLNM6ZABBNyo74xi64gW6GTmArn3_V1N66s=: Activations list loaded
2016-03-30 22:03:11.5653 INFO: FileManagement: COUNTRY begin load countries
2016-03-30 22:03:11.7528 INFO: FileManagement: COUNTRY load completed: 402
2016-03-30 22:03:11.7528 INFO: FileManagement: IOTA begin load database
2016-03-30 22:03:11.7528 INFO: SolarDataManagement: GEOMAGNETIC DATA (DGD) downloading from ftp://ftp.swpc.noaa.gov/pub/latest/DGD.txt
2016-03-30 22:03:11.7528 INFO: SolarDataManagement: GEOMAG data begin download
2016-03-30 22:03:12.0497 INFO: FileManagement: IOTA load database completed: 1178
2016-03-30 22:03:12.0653 INFO: FileManagement: Begin loading SotaDatabase
2016-03-30 22:03:12.0653 INFO: FileManagement: begin load text file H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\summitslist.csv
2016-03-30 22:03:12.2216 INFO: FileManagement: Text file load completed
2016-03-30 22:03:12.2372 INFO: FileManagement: SOTA Summits List (Date=15/12/2015)
2016-03-30 22:03:12.2372 INFO: FileManagement: SummitCode,AssociationName,RegionName,SummitName,AltM,AltFt,GridRef1,GridRef2,Longitude,Latitude,Points,BonusPoints,ValidFrom,ValidTo,ActivationCount,ActivationDate,ActivationCall
2016-03-30 22:03:13.4247 INFO: FileManagement: begin load text file H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\SotaAssociations.csv
2016-03-30 22:03:13.4247 INFO: FileManagement: Text file load completed
2016-03-30 22:03:14.0185 INFO: FileManagement: SotaDatabase loaded
2016-03-30 22:03:14.0185 INFO: FileManagement: TUNE REMINDERS load start
2016-03-30 22:03:14.1903 INFO: FileManagement: TUNE REMINDERS load completed
2016-03-30 22:03:14.1903 INFO: FileManagement: Clublog begin load database
2016-03-30 22:03:14.9091 INFO: FileManagement: Clublog load database completed
2016-03-30 22:03:14.9091 INFO: FileManagement: SCL begin load unique callsign
2016-03-30 22:03:15.1435 ERROR: *** FileManagement: SCL load error ******* [Function: LoadScl] System.InvalidOperationException: There is an error in XML document (6772, 18). ---> System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: EndDate, SCLItem, Items, Scl. Line 6772, position 18.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlReader.ReadString()
at System.Xml.XmlTextReader.ReadString()
at System.Xml.XmlReader.ReadElementString()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderScl.Read2_SCLItem(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderScl.Read3_Scl(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderScl.Read4_Scl()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at LogOM.BL.FileManagement.LoadScl()
2016-03-30 22:03:19.5497 INFO: FileManagement: begin load RANKING
2016-03-30 22:03:19.7216 INFO: FileManagement: RANKING load completed
2016-03-30 22:03:19.7216 INFO: FileManagement: begin load RegExpFilters
2016-03-30 22:03:19.7216 INFO: FileManagement: RegExpFilters load completed Cluster
2016-03-30 22:03:19.7216 INFO: FileManagement: LOTW begin load from file H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\lotw.txt
2016-03-30 22:03:19.9560 INFO: FileManagement: LOTW load from file completed
2016-03-30 22:03:19.9560 INFO: FileManagement: Non Standard callsign begin load from file H:\Documents and Settings\SIGNALINK USB\Datos de programa\LogOM\NonStandardCallsign.txt
2016-03-30 22:03:19.9560 INFO: FileManagement: Non Standard callsign load from file completed
The error message refers to a corrupted line in the SCL file, this would not cause the program to fail to start - Just update the SCL file in the normal way and that should cure it. If it still shows the same error after an update then delete the old SCL file and update using a fresh one.
However your install of the software is to a strange location, H:\Documents & Settings\Signalink USB\...... folder???? why did you not allow Log4OM to install to the default folder?
You are correct regarding admin privileges but of course you failed to explain that you were using XP, this is why we ask users to identify what OS and version of Log4OM they are using when the post on the forum!
