log40m does not see ic7300
docosso
Post by docosso »
I have a new icom 7300 and trying to connect to my computer. running win 10 can someone help please
Re: log40m does not see ic7300
1. Download and install Omnirig
2. Select Omnirig in the Log4OM options CAT/Cluster tab
3. Select the 7300 in the Omnirig settings dialog and match the com port and baud rate to that of your radio
4. Turn on radio and restart Log4OM
docosso
Post by docosso »
thanks Dan I got it working. you the Man!!!
docosso
Post by docosso »
oops sorry I got the wrong name terry thanks
docosso
Post by docosso »
problem solved
docosso
Re: log40m does not change freq. fast enough on ic7300
Post by docosso »
my icom 7300 does not change freq. from the log40m screen at a fast rate can anyone help
On your Omni-Rig Settings screen set the Poll Int. to 100 ms.
This would be for Rig 1 assuming your have your Icom noted for Rig 1.
docosso
Post by docosso »
got it problem solved thanks
