Transverter Offset
M0WTL
Transverter Offset
Post by M0WTL »
Hi
I am new to the software and I can find no reference to how to use the transverter offset function. I have a TS590SG and I use 2m via a transverter that works on the 10m band. Of course when I use this all calls gets logged as 10m.
I need to be able to add the correct frequency but only when using the transverter.
Is there a solution here?
Re: Transverter Offset
Did you try this?
M0WTL
Post by M0WTL »
Thanks for the response and also the excellent software!
I saw this setting but will this looks like a global setting so therefore all but 2m will incorrect. I could not find anything in the manual about it.
Am I misunderstanding the use?
Did you condider using a seperate configuration for transverter use and another for normal operations?
Set up two icons on your desktop for each config perhaps?
M0WTL
Post by M0WTL »
Ok that's a thought thanks!
Don't forget to use the config ID in the shortcut to differentiate between the two ID's
M0WTL
Post by M0WTL »
Just to update, I have managed to find another solution which might be better than running two versions. This i via Omnirg - I made a new rig profile with an offset and now I can just select rig 2 and I get the correct frequency.
I think your solution is better if you have more than one radio controlled by omnirig!
Thanks for your help
M0WTL
Post by M0WTL »
Hi Terry
I am needing to revisit the alternate config idea however I cannot get this to work.
In the shortcut I have this:
"C:\Program Files (x86)\IW3HMH\Log4OM\LogOMUI.exe" -CONFIG=dd671c82-f4d9-45ed-b927-98ac6e846a72
I have tried multiple variants and nothing seems to work.
What am I doing wrong?
Thanks!
M0WTL wrote: 05 Sep 2017, 19:27 Hi Terry
Thanks!
Like this
"C:\Program Files (x86)\IW3HMH\Log4OM\LogOMUI.exe" CONFIG=d08e4e06-c1b1-4904-ae13-4fcecca27abb
Leave out the hyphen (-) before the word 'CONFIG'
M0WTL
Post by M0WTL »
It works! Thanks a lot!
