Multiple Freq Display for Flex
HI8SMX
Post by HI8SMX »
I know softwares are developed for the generality not the particularity, but is there a way (or future update) that Log4OM radio display could display different frequencies according to Flexs slices, just like it displays VFO A and VFO B ?
73, Santiago
HI8SMX
______________
73 de Santiago
HI8O (former HI8SMX) + KB8SM
web: www.hamworld.online
YouTube: hamworldonline
Twitter: @hamworldonline
Instagram: hamworldonline
Re: Multiple Freq Display for Flex
Not sure if that is a limitation of Omnirig or what but would like to be able to log slice B. I have it setup in OmniRig but has only worked randomly over the years.
There are some libraries from FLEX but i didn't have worked on them yet, focusing on core.
CAT engine is expandable (hardly over the visual limitation of 2 VFO's) but some kind of support to Flex VFO's can/will be added in future.
HI8SMX
Post by HI8SMX »
IW3HMH wrote: 16 Jan 2020, 11:42 There are some libraries from FLEX but i didn't have worked on them yet, focusing on core.
Thanks Daniele! Yes, I agree with attention to core first and foremost. If in the future this feature is enabled I'll be happy, if not, I'll be happy as well. I'm very satisfied with Log4OM.
Congratulations on a great job!
______________
73 de Santiago
Old thread :)
But, just for curiosity sake why is the Flex not treated as two radios? I mean the VFOs on a Flex are on separate serial ports. How does Log4OM know they are not two different radios?
HB9VQQ
Post by HB9VQQ »
Rich, I have Slice A on COM16 (RIG 1) and Slice B on COM17 (RIG 2). That's how I switch between Slice A and Slice B in Log4OM.
Roland
Flex 6600 - Spiderbeam
How do you switch back and forth?
That seems to have no effect here Roland.
HB9VQQ
Post by HB9VQQ »
RIG 1
RIG 2
Hope this helps
Yep, that does not work.
Changing 1 to 2 has no effect.
HB9VQQ
Post by HB9VQQ »
Then I guess something is wrong with your setup. Can you show your Omni Rig config and your SmartSDR CAT config ?
