EQSL upload
EQSL upload
Hello, I am new with LOG4OM V2 but my eQSL is not automatically uploaded. Also download from eQSL don't work. I put my login and pasword correst. Same by LOTW upload and Download don't work. QRZ and CLUBLOG work fine.
- 2.jpg (76 KiB) Viewed 5697 times
- 3.jpg (95.41 KiB) Viewed 5697 times
- 4.jpg (61.86 KiB) Viewed 5697 times
Re: EQSL upload
pls provide output of the realtime log while uploading.
Help --> Realtime Log
Is your QTH Nickname correct ?
Roland
Roland
Flex 6600 - Spiderbeam
Re: EQSL upload
Roland,
I might be having an issue as well.
Even though I have the Automatic upload on new QSO checked in eQSL I just did select required. There was over 800 QSOs that needed uploaded.
Did not have any login issues. I did a download right after that and it connected using the user/password without issue.
I also went to eQSL.cc and logged in to verify user/password which was good.
So my upload/download works but does not seem to be automatically uploading them.
Re: EQSL upload
Rich, I have made 3 QSO's today all were automagically uploaded to eQSL and every other external QSL DB's so I do believe this is an individual problem not a general one. I am on 2.2.0.0.
Best is to have a look in your Log, Help --> Open log file , and look for errors.
Roland
Roland
Re: EQSL upload
Must have been an anomaly.
Might is uploading as well. Maybe I needed to force it the first time after V2 install. Because when i went to check the upload it I had 800 set to upload.
So all good for now.
Re: EQSL upload
Roland my QTH Nickname are correct. This my open logfile i check.
73 Pat
73 Pat
LOG4OM2_log_UI_20200131.log
- (31.2 KiB) Downloaded 290 times
Re: EQSL upload
Please email me a support request (Help/Support request) to g4pop (AT) arrl.netON3CQ wrote: 31 Jan 2020, 05:48 Hi,
73 Pat
BY EMAIL ONLY DO NOT POST HERE
Re: EQSL upload
Pat I don't see any upload attempt in your log. Is manual eQSL upload/download working ?Roland my QTH Nickname are correct. This my open logfile i check.
Roland
Re: EQSL upload
My uploads to all services are running well. Please check in the "My Accounts" of eQSL your setted Nickname
is correct. If There´s "Home" you have to enter "Home" in the Log4OM eQSL settings. If it´s another one you
have to use these .... Check out for upper case and/or lower case letters.
Re: EQSL upload
Roland i do new install LOTW and the rest upload fine now.HB9VQQ wrote: 31 Jan 2020, 13:39Pat I don't see any upload attempt in your log. Is manual eQSL upload/download working ?Roland my QTH Nickname are correct. This my open logfile i check.
Roland
73 Pat
