Page 1 of 2
EQSL upload
Posted: 30 Jan 2020, 17:43
by ON3CQ
Hello, I am new with LOG4OM V2 but my eQSL is not automatically uploaded. Also download from eQSL don't work. I put my login and pasword correst. Same by LOTW upload and Download don't work. QRZ and CLUBLOG work fine.
Re: EQSL upload
Posted: 30 Jan 2020, 18:02
by HB9VQQ
pls provide output of the realtime log while uploading.
Help --> Realtime Log
Is your QTH Nickname correct ?
Roland
Re: EQSL upload
Posted: 30 Jan 2020, 18:33
by KD0ZV
Roland,
I might be having an issue as well.
Even though I have the Automatic upload on new QSO checked in eQSL I just did select required. There was over 800 QSOs that needed uploaded.
Did not have any login issues. I did a download right after that and it connected using the user/password without issue.
I also went to eQSL.cc and logged in to verify user/password which was good.
So my upload/download works but does not seem to be automatically uploading them.
Re: EQSL upload
Posted: 30 Jan 2020, 18:38
by HB9VQQ
Rich, I have made 3 QSO's today all were automagically uploaded to eQSL and every other external QSL DB's so I do believe this is an individual problem not a general one. I am on 2.2.0.0.
Best is to have a look in your Log, Help --> Open log file , and look for errors.
Roland
Re: EQSL upload
Posted: 30 Jan 2020, 19:16
by KD0ZV
Must have been an anomaly.
Might is uploading as well. Maybe I needed to force it the first time after V2 install. Because when i went to check the upload it I had 800 set to upload.
So all good for now.
Re: EQSL upload
Posted: 31 Jan 2020, 05:48
by ON3CQ
Roland my QTH Nickname are correct. This my open logfile i check.
73 Pat
Re: EQSL upload
Posted: 31 Jan 2020, 09:05
ON3CQ wrote: 31 Jan 2020, 05:48 Hi,
73 Pat
Please email me a support request (Help/Support request) to g4pop (AT) arrl.net
BY EMAIL ONLY DO NOT POST HERE
Re: EQSL upload
Posted: 31 Jan 2020, 13:39
by HB9VQQ
Pat I don't see any upload attempt in your log. Is manual eQSL upload/download working ?
Roland
Re: EQSL upload
Posted: 31 Jan 2020, 14:00
by DF5WW
My uploads to all services are running well. Please check in the "My Accounts" of eQSL your setted Nickname
is correct. If There´s "Home" you have to enter "Home" in the Log4OM eQSL settings. If it´s another one you
have to use these .... Check out for upper case and/or lower case letters.
Re: EQSL upload
Posted: 01 Feb 2020, 14:33
by ON3CQ
HB9VQQ wrote: 31 Jan 2020, 13:39
Roland
Roland i do new install LOTW and the rest upload fine now.
73 Pat
