CAT OmniRrig Interface
W8QXR
Post by W8QXR »
I am setting up Version 2. I am at the Radio CAT Control Step. When I try Connect/Cat/Show CAT Interface the OMNIRig Interface box does not show. I did try shutting down LOG4OM and reinstalling OmniRig but that did not help. I would appreciate your help
David Altwies
Lake Geneva, WI
W8QXR
Re: CAT OmniRrig Interface
So you have selected OmniRig for Cat type in the settings and are clicking the icon on top to open OmniRig?
I am assuming you are trying to run the version of OmniRig that comes with Log4OM and not the version 2 of OmniRig?
W8QXR wrote: 18 Feb 2020, 21:07 I am setting up Version 2. I am at the Radio CAT Control Step. When I try Connect/Cat/Show CAT Interface the OMNIRig Interface box does not show. I did try shutting down LOG4OM and reinstalling OmniRig but that did not help. I would appreciate your help
David Altwies
Lake Geneva, WI
W8QXR
David,
Make sure you have done your initial CAT setup in the Settings / Program Configuration / CAT interface window. If you choose OmniRig then you also (once the V2 setup is completed) need to choose your rig and settings required there.
Rich's post is good as well, but won't fly until you have set up the underlying basics.
Did you have V2 do the OmniRig installation as part of the V2 installation ... or did you install it by yourself?
The only OmniRig that is supported by Log4OM is the original version that handles "two" rigs. There is an OM in Switzerland who has developed a version of OmniRig that can support up to 4-rigs, but we have been working with that developer to resolve many issues with his version and thus we're not supporting it at this time.
Tnx for starting to use Log4OM V2.
