Cluster MODE vs. MODE TYPE
dl1clm
Post by dl1clm »
Hi All,
Can someone explain to me the difference between "WORKED SAME MODE" and "WORKED SAME MODE TYPE"?
I can't find this in the manual.
Thanks, Dick DL1CLM
Optibeam OB 9-5
KA4CDN
Re: Cluster MODE vs. MODE TYPE
Post by KA4CDN »
No I can't. Don't know what Type means. However, my reason for responding is that in testing to try and duplicate, it seems that once the "initial determination" is made as to worked before/mode/band/etc, that determination remains even if you change bands or mode? (No current CAT control for this test).
Example;
I, w/o CAT control, enter a call I've worked prior with Band and Mode selected as in the prior QSO and get the [WRK BAND MODE] indication. Now, even if I change Mode or Band, the indication remains. I would have expected it to refresh.
FWIW.
Mike
Really loving new V2. Can't wait for updates.
dl1clm
Post by dl1clm »
I assume MODE can be USB, LSB, AM, FM and that this falls under MODE TYPE "phone". RTTY, FT8, FT4 falls under MODE TYPE "digital" and CW falls under MODE TYPE "cw".
So if I have worked with PE1CLM at 20 meters with USB and PE1CLM is on the cluster at 20 meters with AM then the color corresponding to "WORKED SAME MODE TYPE" is displayed in the cluster.
If PE1CLM is on the cluster at 20 meters with USB, the color corresponding to "WORKED SAME MODE"
Is my assumption correct?
What makes it a bit confusing is that we can display "Emission Type", "Modulation Type" and "Spot Mode" in the cluster screen.
73 Dick DL1CLM
Optibeam OB 9-5
dl1clm
Post by dl1clm »
Hi All,
Isn't there anyone who can tell the difference between "WORKED SAME MODE" and "WORKED SAME MODE TYPE" ?
The tests I've done so far don't give an unambiguous result.
Cluster highlight Colors.jpg (25.03 KiB) Viewed 2259 times
Optibeam OB 9-5
