Keeps crashing and crashing...
CU3ED
Post by CU3ED »
A few days ago the Log4OM stopped working.
Now in the last days, keeps crashing and crashing...
Nothing was changed in the station computer, not even updates, but no joy!
I decided to post here this because just a few minutes ago was twice in a row.
What can be done to sort this problem?
Log4OM 2.jpg (189.47 KiB) Viewed 3708 times
All the best, and stay safe,
DF
Re: Keeps crashing and crashing...
I would suggest a CLEAN instal having first backed up your log and having made a copy of your config.json file located in the c:\........\appdata\Roaming\log4omng\user folder
CU3ED
Post by CU3ED »
This is not the best approach/solution to me!
That's my log at risk!
DF
CU3ED wrote: 17 Apr 2020, 10:25 Hi,
DF
Nothing is at risk if you backup first!
The most likely cause of your problem is a corrupt file this way you start with a new clean set of files and you just use your original config file to restore your settings
CU3ED
Post by CU3ED »
OK I will clone the entire disk, just in case!
Thanks,
DF
4z1tl
Post by 4z1tl »
Before uninstalling,Try using a different com port interface if your old one is based on an FTDI or alike USB interface. Sometimes windows updates don't cause trouble... :D
Isaac 4Z1TL
