SO
W8QXR
SO
Post by W8QXR »
I just installed LOG4OM 2 version 2.7.0.0. I am using it with JTDX V2.1.0-rc 149. I am having problems uploading QSO's to LOTW.
LOG4OM settings- Confirmation is set for LOTW, Sent "Queued", Rcvd "Requested" and Main UI Statistic "Worked". I use Queued because I always upload manually at the end of each operating session thus this make sense to me. These are the same settings I think I used with the previous version.
When I go to upload QSO's in QSL Manager nothing is selected. I read the manual and looked on YouTube but could not figure out what is wrong. I then did an edit on several of the QSO's and saw the QSL info was marked No. I changed this to Queued and the Select function worked properly and the upload to LOTW worked as it should.
Your help is appreciated
Dave Altwies, W8QXR
Re: SO
W8QXR wrote: 09 Jun 2020, 01:00 I just installed LOG4OM 2 version 2.7.0.0. I am using it with JTDX V2.1.0-rc 149. I am having problems uploading QSO's to LOTW.
Dave Altwies, W8QXR
Dave,
Now that you have change the labels in the Confirmation area for the External Sources you will also have to make some changes when you are in QSL Manager.
When you do a search or Select Required you will need to tic the "Sent" box and use that drop-down and select "Queued". That should then find the Q's you are wanting to upload.
Once they are uploaded The QSL Manager routine will change the Sent box to "yes".
Give that a try and see if that helps.
W8QXR
Re: SO
Post by W8QXR »
I had QSL Manager set correctly. To have QSL Manager recognize a queued QSO I have to edit the QSL info for the contact. I am not sure how the program changes the QSL info to match the "Confirmation" setting. When doing an edit on the QSO I can see that the "sent" is no and the " rcvd "is no regardless of the setting in "Confirmations". So I set the "Confirmation" "sent" to no and the "rcvd" to no and everything works ok. So, I while I am able to select and upload QSO to LOTW, I do not understand what is going on.
Dave, W8QXR
