CAT Interface need help ...
F6FLU
Post by F6FLU »
I did not understand how the CAT works when we select "Switch to DIGITAL mode when required"
I validated this option by selecting the FT8 mode by default
but in the input interface the mode always remains in USB (I am in USB to do FT8 with my TX (FTdx5000) )
I can change bands and position myself each time on the FT8 frequency in each band, the mode always remains USB
Settings CAT Log4OM2020-11-22 164951.png (46.43 KiB) Viewed 2936 times
So when does the mode switch to "DIGITAL" ?
thank you for your clarifications
Dan - F6FLU
https://F6FLU.org
Re: CAT Interface need help ...
Check your wsjt settings and your Omnirig rig ini file, you either have the wrong setting in wsjt CAT tab for mode or your not using the correct Omnirig ini file
F6FLU
Post by F6FLU »
Thanks Terry
Perhaps but where exactly ?
I use JTDX and Omnirig
On Omnirig I don't see anything abnormal :
Omnirig Settings 2020-11-22 173647.png (14.85 KiB) Viewed 2931 times
and on JTDX Settings I don't know where and what to look for :-)
Dan - F6FLU
https://F6FLU.org
No not there
1. JTDX settings/radio check what is set in the mode section of that window
2. In the Omnirig normal window where you select the rig and com port, check to see if there is an ft5000 ini file with 'data' in the name
F6FLU
Post by F6FLU »
G4POP wrote: 22 Nov 2020, 16:54 No not there
1) ==> The mode is USB
2) ==> I selected with the name :"Ftdx5000MP" But there is also "FTdx-5000MP-D"
I have to select this last one ?
Dan - F6FLU
https://F6FLU.org
1 what are the other modes
2 YES
F6FLU
Post by F6FLU »
G4POP wrote: 22 Nov 2020, 17:05 1 what are the other modes
The other mode are : "None" "USB" "Data/PKT"
but I have to use USB with my personnal interface :-)
Dan - F6FLU
https://F6FLU.org
Select data/pkt in JTDX
Select the data ini in Omnirig
F6FLU
Post by F6FLU »
I’ll try that
Thanks Terry...
Dan - F6FLU
https://F6FLU.org
lb3re
Post by lb3re »
Anyone have 100 % working omni rig with FT DX5000??
