I'm using ver 2.11.0.0 in the contest mode. I noticed that during a recent contest, when I doubled clicked a call sign, my rig changed frequency as expected however, sometimes, the mode also changed. This doesn't happen all the time, maybe 20%. For example I'm working 160m SSB in LSB. Double click a cluster spot and the frequency on my Icom 7300 changes as expected and the mode unexpectedly changes to USB. I'm using OmniRig. This even happens for stations that are identified in the cluster as LSB. Need help trouble shooting. Is this a Log4om issue or OmniRig issue.
Also, along the same line, the filter selection always changes to Filter 2 from Filter 1 or Filter 3. This is consitent with every call selected from the cluster.
Ray Mikula
W9NZ
Mode change LSB to USB with cluster Call selection
Re: Mode change LSB to USB with cluster Call selection
A search reveals that the filter is a known Omnirig issue and the fix is listed
search.php?keywords=Icom+filter
The mode change sounds like you need to set the Omnirig pol Int to 100
